Old 02-Aug-2006, 15:07   #41
Sharpy G Sharpy G is offline
Bikes: 749R 2004
Sharpy G's Avatar
i get yah !
Old 02-Aug-2006, 15:13   #42
Gizmo Gizmo is offline
Mood: is it the weekend yet??
Originally Posted by Sharpy G
i get yah !
Good hopefully the machine shop will understand as well
Old 02-Aug-2006, 15:16   #43
Bikes: 749R 2004
Sharpy G's Avatar
thanx v much Gizmo
will get this done
.................untill I can afford a proper clutch anywayz LOL
Old 02-Aug-2006, 15:23   #44
thanx v much Gizmo
will get this done
It might be worth checking the distance from the plate to the inside of the face where the drum pushes. Sorry hard to explain but the way the slipper works is for the clutch drum to lift and contact the pressure plate pushing it away from the clutch plates and allowing slip. if the new plate is cut away too far inside the clutch won't slip cos drum can't push it conversely if its not as deep the drum will lift the plate early.
Put a straight edge across face of plate and measure down to just inside the teeth at a point where the drum should push, you'll need the same dimension off a 749R to check, using a DPP Bucci it might have different lift or ramps
Old 02-Aug-2006, 15:29   #45
Bikes: 749R 2004
Sharpy G's Avatar
getting my old one off tonight wen I get the bike back and taking both into machine shop tomorrow, that should sort it
Now how do I get the push rod out of the old plate ?
Old 02-Aug-2006, 15:37   #46
drift and hammer......
Old 02-Aug-2006, 15:39   #47
Is that an 'approx' drift and hammer?
Old 02-Aug-2006, 15:41   #48
Bikes: 749R 2004
Sharpy G's Avatar
I can do the drifting bit !!!
Old 02-Aug-2006, 15:43   #49
close enough
Old 02-Aug-2006, 16:06   #50
oooh..............do you want to touch it?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:01.
