Old 14-Jan-2009, 19:58   #41
But the wheel is not modified in any way by adding weights, it is just balanced and yes the same can apply to a complete crankshaft assembly, in that you can mix and match rods pistons etc to balance a crank without having to modify the crankshaft.
But few people resort modifying by drilling or grinding their wheels to acheive balance.
So back to the rule, it says No modification of the Crankshaft, It does not say no balancing of the crankshaft asembly by selecting matchingcomponents
As for 916 wheels as far as I know a 916 front wheel is no different from a 620 front wheel and as the rule says
1.6.5 Wheels
Wheels including diameter and rim width must remain as originally produced by Ducati since 1992 for the 600/620 bikes.
Front wheel 17” X 3.5”, Rear Wheel 17” X 4.5”
There is no issue with using a 620 front or rear wheel in a 583 and if the 748/916 front wheel is the same part as a 620 it can also be used.
Did they fit any 620s with 5 spokes as found in the 996, if not then I doubt these would be allowed
Old 14-Jan-2009, 20:01   #42
Originally Posted by Lily
count me in.. i can crash them just as well as a DD bike
Is that Druids?
Old 14-Jan-2009, 20:02   #43
Originally Posted by paynep
Quite right re the last sentence
For example the same front wheel (501.2.069.1AB) is fitted to both MY03 620 and 750 Monsters.
So if I took a front wheel off a 750Monster from another year and used it, would it be illegal?
Mind you, my bike has a 900ss frame, Mhe900e forks, a 750ss rear wheel and an ST2 front wheel so I might as well be banned now and save on all the race entries...
...there's a saying that goes along the lines of ".......won't be troubling the scorers!!"
Old 14-Jan-2009, 20:08   #44
paynep's Avatar
Mood: Wet wet wet
Nope, not even the Capirex as standard - I've already checked.
Mind you, there are mag wheels listed in the DP catalog as suitable for the 620s - surely that complies with "originally produced by Ducati since 1992 for the 600/620 bikes.
Front wheel 17” X 3.5” " ?? Then I figured the 500quid would be better spent on improving ability through tracktime or Magners. Guess what I chose?
Old 14-Jan-2009, 20:10   #45
paynep's Avatar
Mood: Wet wet wet
No change there then
Think I'd better use the spare bike then - oh wait, its got a 999 fuse in it
Old 14-Jan-2009, 20:14   #46
mjbayley mjbayley is offline
mjbayley's Avatar
Mood: Been Testing the 3 P's (Pizza, Pasta, & PERONI!)
Lightbulb Lighter Wheels you say......?
1.6.5 Wheels
To quote Sir Falon's Monster and SS book:
1998 onwards
Frame and Cycle Parts
" With Brembo wheels..........from the 916 and ST2 having larger diam. (25mm) axles.........."
".....the wheels were also lighter than before at 225 grams on the front and 800 grams on the rear"
It's easy to spot which ones they are if you compare them side by side.
However, ther is only one sort that will slot straight into a Monnie or SS without palava with the rear wheel bearings and wheel bearing spacers.
(and I'm not gonna tell you which one that is.......;-) )
MarkO
Old 14-Jan-2009, 20:16   #47
Drinking Magners while riding around a track by any chance
Would explain a few things
Maybe the wording should be changed to "originally fiited by Ducati since 1992 for the 600/620 bikes
Old 14-Jan-2009, 20:20   #48
nogaromill998 nogaromill998 is offline
nogaromill998's Avatar
To a certain extent balancing, expecially on the Class B engines is not worth the expense as they do not rev that high anyway and are somewhat overengineered for 52bhp.
That is an opinion, nothing more. And at the end of the day there is a bhp limit anyway......
Old 14-Jan-2009, 20:53   #49
Matt-T28 Matt-T28 is offline
Matt-T28's Avatar
Mood: 2008 Desmodue Class B champion
Just to add my own thoughts on this subject,
I dont see myself that David will have anything better than someone else will have.
The rules are designed to be fair to people and designed so that no one person can have an unfair advantage to somebody else.
David hasn't got anything in his engine that would not have come out of the factory in another bike on a different day of the week.
Its just that some engines are better than others as some will have fractionaly lighter parts, thats just the way it is. Its luck of the draw but all David has done is to turn his engine from a slower one with slightly heavier parts into one of the better engines.
I dont see the problem with that, as someone could go out tomorrow and buy an engine thats never been apart before that has a lighter crank than his but it would still be a standard engine.
Old 14-Jan-2009, 21:09   #50
vespa vespa is offline
Bikes: Super Twin 800; DD B; S2R 1000
vespa's Avatar
Mood: DD class B
So balancing actually reduces the chances of engine failure. You don't need to do it but once you open you engine it would be daft not to do it, as long as you keep within the factory weight tolerance limit. An alternative as somebody suggested would be to buy another engine atogether, play and pray...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:38.
