Old 17-Jun-2004, 18:14   #41
Mr_S Mr_S is offline
It's all fitted up now
Radial Discacciati
HEL Lines
EBC HH pads
DOT 4 Fluid
Cleaned all the calipers up at the same time, just got to get some spades for the brake light switch then off to pull stoppies
Old 18-Jun-2004, 09:17   #42
m1keyp m1keyp is offline
Mr-s Any prob;lems with the brake light switch?
I cannot get mine to lock off
Mike
Old 18-Jun-2004, 09:31   #43
Mike,
It took me a while to realise that there's a tiny little grub screw (allen bolt) in the pivot point of the lever that you tighten up, and not the big nut that I tried first. The instructions are a bizarre translation from Italian (as bad as BabelFish) and not very clear.
This pic should help you find it, although if you're tightening that already, then I don't know
http://www.chathamclose.com/pics/mc1.jpg
Jason
[Edited on 18-6-2004 by Mr_S]
Old 18-Jun-2004, 11:09   #44
You got instructions?????
Thanks for that i had not noticed it and never would have.
All sorted now
Mike
Old 18-Jun-2004, 12:46   #45
DJ Tera DJ Tera is offline
LOL you didn't throw the packaging away did you?
Old 18-Jun-2004, 13:20   #46
Mine arrived in a cardboard box and bubble wrap, I have trouble with the bleed on the master cylinder weeping, did your instructions include torque settings.
I am S**t scared of tightening any more
Old 18-Jun-2004, 14:49   #47
I stuck with the torque settings that came with my brake lines
min 14ft/lbs
max 24 ft/lbs
If it's tight & weeping, something's not right, it should only need a slight nip up to close it fully.
The instructions (all 4 lines!!) were printed on the back of the packaging
Old 18-Jun-2004, 17:53   #48
The brass bleed nipple on the master cylinder is where the weep is coming from.
Strange i dont feel that they have been over tightened.
Old 20-Jun-2004, 14:01   #49
Mike,
Is the weep you're getting constant each time you hit the lever, or is it that there's a bit of fluid around the nipple after you went out and rode it?
If it's the latter, it could just be the last dregs of fluid left in the bleed nipple being thrown out, as there's always a little left in the end of the nipple after you close it off.
On another note,
These brakes are scary good now , I've got to completely rethink my braking points (and probably adjust the front suspension too...)
I also changed the rear hose (it came in the kit so..) and after bleeding fresh fluid through until it ran clear and bubble free, it's still cr@p.
Think I might bleed the clutch through next..
Old 20-Jun-2004, 15:00   #50
I think its the dregs, the brakes are awesome, SO MUCH FEEL
Did you get the clutch lever aswell? If not get it. I have it fitted with the MPL tuning parts slave (£85)that the guy sells on ebay and the difference is fantastic.
Thanks for the reply
Mike
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:14.
