Old 22-Feb-2012, 22:45   #41
All the pics above have 320mm Discs standard size for most post 1991 Ducatis
Here is a pic of my 2 into 1 conversion, top pic is the standard 2 into 2, bottom pic my coversion pipework
Old 23-Feb-2012, 19:09   #42
flatline flatline is offline
Bikes: Vtr1000 & 750ss DuCafe Racer. Leeds area
flatline's Avatar
Mood: Upbeat
Sweeeeet
Have you made it yourself?
If you have I hate you!! lol
What price do they run to?
Have been looking at this:
http://www.ebay.co.uk/itm/120613435262?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_1037wt_698
Still waiting for the tank to be repaired after the powdercoaters dropped it
Maybe I will look into the possibility of fitting Super Motard wire wheels
Although the first thing is to get the old girl back on the road
Speak soon
Regards
Old 23-Feb-2012, 20:00   #43
Originally Posted by flatline
Sweeeeet
I wish, had it made locally £120 plus the cost of a link/adapter pipe to suit what ever can is been used. It uses the Standard 40mm diameter headers off a 900SS
That looks a bit bulky, to get an idea of what is possible with Exhausts you need to get a long to a DD race meet and see the different setups that are used
Old 23-Feb-2012, 21:39   #44
Quill exhausts do some really good custom stuff:
http://www.ebay.co.uk/itm/170789117162
Old 23-Feb-2012, 22:46   #45
if you want custom, go see JAC Exhausts in Nottingham, great value and great job
Old 24-Feb-2012, 13:06   #46
flatline's Avatar
Mood: Upbeat
Thanks guys
Old 25-Jun-2013, 12:52   #47
flatline's Avatar
Mood: Upbeat
Update June 2013. Stuck on electrics
Its been a while, with plenty of things getting in the way of the build
The main one being the electrics
As some of you will have read, I am building a cafe racer using a 1992 750ss as a donor bike
What has held the build up is the electrics
As suggested I have a Monster loom (supposedly) from a bike of the same year
However all the connectors are different
This shows the RH switch cable connector: 750 on first, Monster on second
It's the same with the other cables, all different
The monster loom also has three relays, where all the wiring diagrams point to only having 2..........wtf??
So to the questions:
1. If the Monster loom is from a 1992 model, should it have the same connectors?
2. Anyone know what the third relay is for?
3. Finally, are there any electrical guys in the Leeds area?
I have spoken to a couple and get "Oh its a ducati, sob sob, the wiring is so hard to work on" Bunch of tossers
Old 25-Jun-2013, 12:56   #48
flatline's Avatar
Mood: Upbeat
Update June 2013 Some good news
Finally got the exhausts sorted
Also cut down the rear of the frame, welding in a new piece
Now need to get the rear curved end made
Old 25-Jun-2013, 17:27   #49
I will need to check but one of the relays may be for the Carb heaters fitted to some models
RHS switch gear has always been different between the Monster and the SS, with the Monster using the same as the 748, 916 etc
Old 25-Jun-2013, 19:28   #50
flatline's Avatar
Mood: Upbeat
Thanks buddy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:24.
