Old 09-Nov-2006, 19:50   #71
Gaz 748's Avatar
Dylan " The Spacey Rabbit " will do as he`s the only one left, " Man "
748R - Less is more !
Old 09-Nov-2006, 19:50   #72
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
Originally Posted by Gaz 748
Jeff is Brian the Snail
We'll just have to wait and see Sheep Shagger about that one, just wait till my bike's back from service after I get back in December.
I think we can safely say my ST will stomp all over that little FS1E of yours!
Old 09-Nov-2006, 19:53   #73
doogalman's Avatar
Or Mr McEnery, on his bike.
Old 09-Nov-2006, 19:55   #74
Gaz 748's Avatar
Ok you can be Dylan if being Brian upsets you so much.
Old 09-Nov-2006, 20:03   #75
jeff st4s's Avatar
Dylan " The Spacey Rabbit ".
I'd rather be a Space Cadet!
Old 09-Nov-2006, 20:14   #76
Florence Florence is offline
Florence's Avatar
Location: Enjoying the most of my hard earned wages and
Mood: living my life to the full
Good Grief!! You lot are REALLY showing your age!
Old 09-Nov-2006, 20:26   #77
jeff st4s's Avatar
What we remember or how we are acting?
Old 09-Nov-2006, 20:35   #78
Florence's Avatar
BOTH OF COURSE!!
Old 10-Nov-2006, 00:21   #79
Founder Member
Paul James's Avatar
Originally Posted by doogalman
One for the old boy (Monty);
Do please tell us a bit more about the Triton.
I built one on a wideline frame, put in a fairly trick motor for its day; 6T bottom end with the T120 Bonneville barrels, Splayed head with central plugs, high comp pistons, E3134 cams and a K2FC magneto, ran on 2 big Amal Monobloc carbs.
Thinking back I reckon our rear tyres were about the same width as the fronts on most modern sports bikes and the profiles were far from ideal. Maybe some of you other "old boys" will remember the Avon "Trigonic" tyres ?
http://www.multirole-eng.com
Old 10-Nov-2006, 06:32   #80
doogalman's Avatar
This was last winters project. Had promised myself since 1978 that i would build one after i turned one down for £160.
Most of the bits are from auto jumbles , ebay and hunting down. The motor is a 650 tr6 in standard trim. As i wanted to run standard for a while before i start to do any work on the motor. It runs ok has led the Surrey bimble run. is great run to ride. The onle things i didn't do on it as i farmed it out, were lacing the rims and paintwork.
Have built a dozen or so bikes over the years , but this one is for me to keep. Normally i get fed up and sell it after a while of use.One of the other interesting ones i built was a tuned xbr500 lump in a tzr125 deltabox frame, but that is another tale.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:37.
