Old 10-Nov-2006, 09:37   #81
Founder Member
Paul James's Avatar
Originally Posted by doogalman
This was last winters project. Had promised myself since 1978 that i would build one after i turned one down for £160.
Most of the bits are from auto jumbles , ebay and hunting down. The motor is a 650 tr6 in standard trim. As i wanted to run standard for a while before i start to do any work on the motor. It runs ok has led the Surrey bimble run. is great run to ride. The onle things i didn't do on it as i farmed it out, were lacing the rims and paintwork.
Have built a dozen or so bikes over the years , but this one is for me to keep. Normally i get fed up and sell it after a while of use.One of the other interesting ones i built was a tuned xbr500 lump in a tzr125 deltabox frame, but that is another tale.
Be interested to hear what you do to the motor if you decide to "breathe" on it a bit ! I've got a couple of spare kickstart return springs knocking about somewhere if you ever break yours, they did seem a bit prone to breaking. We also devised a method of stopping the pushrod tubes from leaking oil. I know of the whereabouts of a Triton and once I've made space in the garage by selling the ST2 it could well be in there as a winter project.
http://www.multirole-eng.com
Old 10-Nov-2006, 11:12   #82
doogalman's Avatar
No deffinate plans at the moment. Othere things on the go , house in Germany/ overseeing Kim's NC30. Plus all else that life serves up.
Will probably stay 650 as 750's are a bit too vibey. May well stay with a single carb as the midrange is allways better on a sinle carb as oppossed to twin. cams pistons and porting will more than likely be the 1st stage. We'll see in the coming years. Want to keep her rideable and reliable.
Old 13-Nov-2006, 13:09   #83
doogalman's Avatar
So how's the 400 coming on ??? Is it time for an update??
Old 13-Nov-2006, 14:28   #84
Florence Florence is offline
Florence's Avatar
Location: Enjoying the most of my hard earned wages and
Mood: living my life to the full
Back end bits cleaned. Rear wheel masked up and middle bit (spokey lookin bit) now sprayed with primer. Swing arm (the bit under the seat?? I think thats what its called) also primered. I need to ask my Workshop Manager if he will actually spray the paint on as I was a bit nervous with the primer. Pretty please
New chain and sprockets gotta go on. When the rear wheel is back on then it's upto the front end. I have gotta chat to one of my clients really nicely and see what deal he'll do to spray my fairing etc.....
Coming along slowly but surely. My overalls are now no longer spotless red. My knees are sore grappling about on the floor. My nails are broken and have oil under them (even tho i haved scrubbed them till they go red)!
BUT it's gonna look good when it's finished.
Old 13-Nov-2006, 19:03   #85
Martinp Martinp is offline
Martinp's Avatar
Mood: 748ish
One for the old boy (Monty);
Ere you know your tax is out of date.
Old 13-Nov-2006, 19:31   #86
doogalman's Avatar
Ignore that. it was just an old disc holder i had to hand.
Old 13-Nov-2006, 19:46   #87
doogalman's Avatar
That'll be the Rear subframe.
Then i can take the blame
I wonder who that is then??
No change there then
I hope so
Old 13-Nov-2006, 19:55   #88
jeff st4s jeff st4s is offline
jeff st4s's Avatar
Mood: Looking for a one way ticket to the 'Ring.
[quote]
If I didn't know you 2 better, you could easily be reported for wife abuse.
Old 13-Nov-2006, 20:01   #89
doogalman's Avatar
[quote=jeff st4s]
Is a mans kingdom no longer his garage??
Had her on the garage floor all taped up last night!
Old 13-Nov-2006, 20:23   #90
jeff st4s's Avatar
You should try velcro straps rather than tape, easier to re-position and re-usable.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:39.
