Old 14-May-2006, 23:47   #1
khushy khushy is offline
khushy's Avatar
if I was you - and as you say its been recently greased - I would CAREFULLY use a samll drill bit - drill a tiny hole in whats left of the bolt - get a tap slightly bigger than the hole you have just drilled - and start tapping into the hole - then try and reverse out the bolt by unsrewing the tap.
this sounds crazy - but its worked for me several times - the last time being a siezed and shagged Ti bolt in a rearset - a tap usually snags nicely on a new thread it has just cut.
Khushy
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:38.
