Old 19-Feb-2017, 18:23   #1
Logi Logi is offline
Bikes: Ducati 750s IE Dark.
Mood: crabbit
Unhappy Help Needed, Dead Duc
Ok folks, needing some advice, bike's been off the road for a wee while now in one of my sheds. last time it fired up it ran for a wee while and cut out, I assumed it was just needing a service.
Fast forward to yesterday, new battery, cranks it over, no go.
No sound of the fuel pump priming.
Replaced the wee black relays under the tank.
Removed the pump. 12v, pump is pumping. doesn't seem to be getting 12v to the pump, getting power to the pump fuse.
Any ideas? I've reached the limit of mine
Old 20-Feb-2017, 21:35   #2
marklwhittaker marklwhittaker is offline
check the wiring in the kill switch
and also the block connector at the headstock
look for any burnt out terminals etc
just an idea
Old 20-Feb-2017, 22:30   #3
Mood: crabbit
Problem solved(well, identified anyway) it's the wiring from the connector to the pump, must be broken at the seal in the bottom of the tank, Wee trip to Ducati Glasgow for a price tomorrow
Old 20-Feb-2017, 23:36   #4
probably going to cost a bit, same one is used on other Ducatis, I take it is the one with the black 2-pin connector that goes into the pump
Old 21-Feb-2017, 22:34   #5
Mood: crabbit
Yes, and yes, basically £130 Got a wee plan to try first tho
Old 22-Feb-2017, 23:16   #6
I repaired one on my 750SSie Minitwin about ten years ago, I managed to dig away a bit of the potting compound and solder a new wire on to the damaged one
Old 05-Mar-2017, 21:45   #7
Mood: crabbit
Well, that was a resounding failure, drilled out the wire from the epoxy, dropped some solder down in, new bit inserted, more solder, new wire, voila! It works.
Put it back in, the **** plastic nut fractures as I tighten it
So my wallet is now crying
Old 06-Mar-2017, 10:12   #8
I'm sure there was a place in the States that made replacement nuts from alu just for this purpose? Might be worth a search to see if you can find a replacement first before a whole new unit!
Old 06-Mar-2017, 21:03   #9
Someone out there was making replacement nuts in alloy
I think they were around £24 last time I looked
Old 06-Mar-2017, 21:04   #10
gone up a bit
http://www.ebay.co.uk/itm/CNC-machin...AOSwBLlVMX6 w
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:56.
