Old 27-Apr-2017, 10:41   #11
Sorry to hear of your off Col, hope you have recovered?
I'm pretty sure the steering lock is just a pin that moves into a hole around the steering head, hopefully, just have a look for a displaced cable around the steering tube that is stopping the pin from latching.
good luck
Old 27-Apr-2017, 15:18   #12
Not sure if you've got a bent steering stop - common when dropped and easy to do - as this may stop the steering from locating correctly. Worth checking to see if it all lines up correctly.
Old 28-Apr-2017, 08:44   #13
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
Thanks Ant, I'll check.
Old 11-May-2017, 20:55   #14
doogalman's Avatar
Also not posted for a long long time, but still look in on a regular basis. Sorry to hear of your bad luck Col. Hopefully you get everything sorted and life moves on, tough at times !-)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:40.
