Old 16-Jan-2005, 16:30   #1
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
998 Rev-counter problem - can anyone help?
Hi Ducati Gurus, your assistance is needed.
Half way through my ride today my rev-counter gave up the ghost.
It registers between zero and 1.5K rpm, no matter what revs the motor is turning.
Everything else is fine - in fact it's running really sweet.
Being a bit of an electrical baboon, and not having a 998 manual to assist, I'm not sure where to start on this.
Does anyone out there have any helpful suggestions.
Old 16-Jan-2005, 16:40   #2
Electronic tachometers give erratic readings when their base voltage is low, usually caused by a loose or corroded electrical connection.
Usual suspects:
Most likely - Intermittent power or earth connection
Next likely - Intermittent rpm signal connection
Least likely - Tachometer internal problems
Since the bike is running OK, the RPM sensor gap, the sensor itself, and wiring back to the computer are not the problem. So, you need to check all the connectors between the computer and the tach. Check for a loose or corroded electrical connection at the battery, the fuse, and any in-line connector. Remove, clean and tighten the two battery connections first, next the connector at the instrument cluster, then at the fuse, and lastly at the wiring harness connections.
If you fail to find a problem, try to borrow a tach to verify that it’s actually the problem, before buying a replacement.
Old 16-Jan-2005, 18:09   #3
Totto Totto is offline
Yep as Shazzm says , i had similar probs with my 998 tacho I traced it to a faulty earth due to a light bulb wire touching the headlight surround !
Old 18-Jan-2005, 15:18   #4
Bikes: 998Bip
Mood: Carbonara
Thank you Shazaam and Toto,
Will check all the connectors this week-end.
I've heard that Ducati installed a new design tacho on the 998, which was prone to failure. And that Ducati has replaced these with the old style item, when needed.
Do you know of this occuring in the UK, or is it just an American thing?
Spinoli
Old 18-Jan-2005, 17:55   #5
My tacho was replaced like for like
Old 19-Jan-2005, 19:39   #6
Nattyboy Nattyboy is offline
Nattyboy's Avatar
Mood: Back down to 3 :>(
Spinoli..have a brand new in the box 916 tacho (original item with 'ducati racing' on it) in the garage if you need it..
Nat
Old 19-Jan-2005, 22:32   #7
I had the same on mine - turned out to be the earth on the battery was not seated correctly even though it appeared to be. Just unscrewed it and did it up again and it went away.
Old 19-Jan-2005, 23:55   #8
BDG BDG is offline
BDG's Avatar
Nat
You must have some garage, you seem to be better stocked than Ducati Manchester
Old 20-Jan-2005, 09:18   #9
Nattyboy's Avatar
Nat
My own little aladdins cave BDG..!!!
Nat
Old 20-Jan-2005, 14:30   #10
Bikes: 998Bip
Mood: Carbonara
Hi Nat,
I'm interested in your spare tacho - I do hoard stuff for that big bad day.
Is it a straight swap onto a 998? (The ECU on the 998 is different)
How much do you want for it?
Feel free to get in touch on:
richard_breeze@jordans-jsy.com
or
spinsown@hotmail.com
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:45.
