Old 09-Feb-2005, 15:28
stephen hall's Avatar
stephen hall stephen hall is offline
will i burn my butt?
can i replace the four bolts holding the subframe to the rest of the bike with stainless I have replaced all other [ non stress areas] with stainless and these would just finish her off or am i likely to drop through and burn my arse on the rear tyre?D
Old 09-Feb-2005, 15:31
keefer's Avatar
keefer keefer is offline
I thought stainless was ok for stress points as well. ?
its alloy that isn't
Old 09-Feb-2005, 15:44
stainless
I was told that stainless is softer than the bolts [alloy] that the bike was fitted with on constrution and if you are going to use stainless then use a smeer of copper grese and dont over tighten but i aint no engineer so any advise would be much appreciated
Old 09-Feb-2005, 15:45
Steve M's Avatar
Steve M Steve M is offline
Mood: Sans moto
Don't worry about it, the tensile and shear load capabilities of stainless steel and the plated ones are close enough for it not to be a concern. They will have used a factor of safety of at least 5:1 at the design stage, the subframe would probably bend before the bolts failed. (unless it's a Suzuki - then it will just snap off!!!)
Old 09-Feb-2005, 15:49
Stephen...who come you are posting in the forum....is there something we should know ???
Frank
I've had mine on stainless for a few years now. My ass is still in one piece with no burn marks whatsoever
Old 09-Feb-2005, 15:51
thanks for the advise fitting them toot sweet!
Old 09-Feb-2005, 16:08
Festa748's Avatar
Festa748 Festa748 is offline
Yer ill second that i put stainless ones in mine and with fat arse on it is still aint broke em
Old 09-Feb-2005, 16:18
Steve M's Avatar
Mood: Sans moto
Stephen
Following on from u2u, have alook at THIS thread.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:35.
