General Motorcycles only
Old 11-Feb-2005, 18:02
Ooo! Ooo! I'll have them if Ali doesn't....
Old 11-Feb-2005, 18:35
keefer's Avatar
keefer keefer is offline
anyone know if you can get those callipers in the larger mount 60-65 I think.
I don't like the adapter plates
Old 12-Feb-2005, 13:19
FiscusFish's Avatar
Originally posted by bolds
P.S £107 each plus vat for New ones
For the ductile iron disks? You sure about that? SuperLight ones are listed around £220ish plus vat.
Darren
Old 12-Feb-2005, 13:27
moto748 moto748 is offline
£107 is what I was quoted a while back for stock discs for my 2001 748.
But, a question. The discs ali bought, and the ones shown in the pic in his (?) later post, have circular holes in the carrier. These are the same discs I had on my (T reg) 750SS.
The later discs on my 748 have "sector" shaped holes (like a piece on an orange). Sort of wedged-shaped with rounded corners.
Now older discs with the round holes often come up on Ebay.
Are they fully exchangeable with the later ones?
TIA
Old 12-Feb-2005, 19:39
sparkin's Avatar
sparkin sparkin is offline
Afraid not,buy Gordy`s 888 then they`ll fit straight on
Old 12-Feb-2005, 19:52
keefer's Avatar
not for me, but sure someone will it looks a good bike
Old 12-Feb-2005, 20:43
FiscusFish's Avatar
TIA
That's more like it. Last years price list shows the "normal" discs at £100.69 plus VAT....
As far as I'm aware all the discs for SBKs and SS's are interchangable with the exception of the "R's" (?). Obviously the 999/749 style ones are different.
Darren
  #18
Old 12-Feb-2005, 21:25
bolds bolds is offline
No that's for the standard one as Ali has bought off Ebay
  #19
Old 12-Feb-2005, 23:42
https://www.harris-performance.com/w...&Catalog Body
BREMBO DIRECT REPLACEMENT FRONT BRAKE DISCS
Harris Super Bikes; Ducati 916/748/996
These brake discs are designed specifically for trackday and race use. They are fully floating which gives greater heat dissipation as well as utilising the trademark Brembo drilled rotor. In addition, the WIDE rotor is made from a rough cast Stainless Steel and the narrow track (actually Brembo’s full SBK race disc) is made from a true cast stainless steel, which is superior to other brands. Gold machined aluminium centre. We recommend using Sparco SR-11 or RR-01 brake pads.
· All Direct Replacement discs are 320mm, so you may need to fit caliper spacer/bracket kits if shown
· WIDE = (5mm thick wide track) Trackday disc can be used with all caliper types
· Narrow track discs (08.6703.11 & 08.6703.69) fully cast stainless steel 6mm thick SBK race spec. For race calipers.
Price for the discs are £123.14 each plus VAT
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:46.
