Old 14-Mar-2005, 17:18   #1
m1keyp m1keyp is offline
REMOVING THE OIL FILTER
Please can someone enlighten me as how the internal oil filter is removed on a 2002 748?
Not the screw on cartridge
The pictures in the haynes manual are different to the pictures in the ducati parts list.
Any help would be appreciated.
Regards Mike
[Edited on 14-3-2005 by m1keyp]
Old 14-Mar-2005, 17:21   #2
It's in the same place but hiding behind the "plug" with a 14mm hex drive.
Unscrew the plug then using the same allen key or socket bit unscrew the filter.
Old 14-Mar-2005, 17:22   #3
Harv748 Harv748 is offline
Harv748's Avatar
Its the largish hex head/plug on the RHS of the bike, near the bottom of the casing.
Undo, and there is a wire guaze tube inside which either:
a) comes out nice and easy with the plug or
b) needs an allen key to undo a small retaining bolt inside before removal
...as mine came out with the plug, I can't tell you what size the allen key is needed if you have that type!
Sure nelly et al will be along in a mo to tell you...
Well what do you know...speak of the devil
[Edited on 14-3-2005 by Harv748]
Old 14-Mar-2005, 17:29   #4
The problem is that it is Bl**dy tight then as is would not inscrew
Thanks for the quick replies
Old 14-Mar-2005, 17:50   #5
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Yep, it'll go with a bbbbbang.
Old 14-Mar-2005, 17:58   #6
Are we talking the small "brass" coloured alllen key bolt underneath the large hex bolt?
Old 14-Mar-2005, 18:11   #7
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
There's a bit of info here from when I changed my oil and filter a while ago:
http://217.199.188.40/xmb/viewthread...10414#pid85330
Ade.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:21.
