Old 27-Mar-2005, 20:55
adam adam is offline
Mood: happy
engine troubles
996R, went on a ride out today, first half of the day no problems, pulled up at a closed cafe, went to start the bike again and it would only rev to two thousand then back fire, the engine wouldnt cut out but just pop. Tick over is spot on problem starts when you try to rev it.
What do you think?
Old 27-Mar-2005, 21:19
Felix Felix is offline
Check the throttle body sensor. Don't know for sure obviously, but what you describe is exactly what happens if it's not plugged in. I missed an entire trackday once because I forgot to plug it back in. Yours might have packed it in.
Old 27-Mar-2005, 22:05
Mood: happy
Felix, when the RAC turned up today I started the bike and hey presto no problem, revved perfectly. I rode it about two miles with him following me then pop bang it happened again. i then had a long wait for the recovery vehicle. Could it still be the sensor?
Old 27-Mar-2005, 22:40
Check the electrical connections first. The sensor could be intermittent or when it gets warm. Not unheard of.
Old 27-Mar-2005, 22:50
Mood: happy
ill have a look tomorrow, just about keep my eyes open, knackered. Thanks mate.
Old 28-Mar-2005, 08:12
Goofy_DK Goofy_DK is offline
Have you solved the problem?
It could be a small piece from the gearshift spring sticking to the magnetic pick-up? Have you cheked magnetic drain plug for items. A mate just had the same problem and it was a broken sping causing the misfiring problem. It shifted as usual.
Old 28-Mar-2005, 09:58
Mood: happy
Goofy, I take it you need to remove the side casing to see this?
Old 28-Mar-2005, 10:00
Yes, but you could try to take oil drain to look for pieces.
[Edited on 28-3-2005 by Goofy_DK]
Old 28-Mar-2005, 10:01
Mood: happy
I had just done an oil change the previous day, no problems with it then. what might i find on it?
[Edited on 28-3-2005 by adam]
Old 28-Mar-2005, 10:08
Well, maybe a 1,6mm Ø piece, but the plug is not very magnetic so maybe nothing. Do you have a flexible magnet tool, you could try to stick it into the sidecase?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:24.
