General Motorcycles only
  #21
Old 18-May-2005, 17:05
I painted mine myself, using PlastiKote Bright Red #1120 as that's a very close match for Ducati Red.
If you use their matching grey undercoat and laquer, you get a very nice finish.
The trick, as said before, is to get the panel as good as possible before painting - sand, fill, sand, fill, etc. Then primer it and work out any imperfections. Then paint it, and again sand it down where it needs it. Finally finish off with some laquer.
Don't rush it and it will look good - leave plenty of time before coats of paint otherwise it will run and you'll be back to square one.
  #22
Old 18-May-2005, 17:06
PS. PlastiKote is about a fiver a tin from B&Q, and you'll need about 1 can of primer, 2 cans of paint and one of laquer for a single panel.
  #23
Old 18-May-2005, 18:43
BDG's Avatar
BDG BDG is offline
Antonye
Your mood says 9th in the championship.
I thought you might be predicting promotion for Norwich for next season
Sorry that was evil after the pain of relegation but i've been there many times myself as a Sunderland supporter
  #24
Old 18-May-2005, 22:07
dave996's Avatar
dave996 dave996 is offline
Mood: Fed up...
[Edited on 18-5-2005 by dave996]
  #25
Old 18-May-2005, 22:12
dave996's Avatar
Mood: Fed up...
Don't know what happened there
As I was saying thanks again, was going to get someone else to paint them but he was after £150 maybe more! and that was ment to be a backhander, so I think I'll give it a go and see what happens.
Cheers to everyone for the advice and I'll let you know how it goes.
Dave
  #26
Old 18-May-2005, 23:19
ttstu ttstu is offline
Mood: On the mend!
Looking forward to seeing the finished product.
  #27
Old 19-May-2005, 01:23
Even if you paint it yourself and don't like it, you'll have only spent 20-30 quid on paint. It's not a huge amount and it's actually quite difficult to get wrong!
Post some more pics as it's looking good so far.
  #28
Old 20-May-2005, 19:17
dave996's Avatar
Mood: Fed up...
How much rubbing down do I have to do before I paint, ie does all the red paint need to be removed or do I just need to rough it up so that the undercoat will bond
  #29
Old 24-May-2005, 10:33
dave996's Avatar
Mood: Fed up...
Just put the last coat on the bellypan, now do I rub it down then laquer or rub it down polish then laquer or just laquer
  #30
Old 24-May-2005, 11:29
I think you just need to rub down, clean and lacquer, it'll look flat before you lacquer it but as soon as the lacquer hits it - BLING!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:41.
