Old 04-Jun-2005, 13:08   #1
Rob748 Rob748 is offline
Handlebar position
Ok, is there a way of making the standard handlebars slightly adjustable. What I mean is can you get them to angle further forward than the standard position?
Old 04-Jun-2005, 15:05   #2
L3OONY L3OONY is offline
Mood: Mildly reckless...
Don't know what model you've got but it appears that mine could be angled ever so slightly forwards by releasing the two bolts on each clip-on.
Don't know whether this would foul on anything when turning the bars though?
Out of curiosity Rob, why would you want to do this?
Old 04-Jun-2005, 17:50   #3
You can push them further forward, reducing the rake, by taking them off the bike and grinding down the pin that locates them with the top yoke. Make sure they are securely fastened back on though.
Watch out for fouling problems with the reservoirs. Should be fine though.
A more exotic solution is the SpeedyMoto top yoke. As well as looking fine, it'll allow the bars to be lifted up to 20mm and also offer about 5 degrees of rake adjustment. The location for the pegs is slotted rather than just a simple indent. Not cheap tho'
Old 04-Jun-2005, 18:09   #4
Gaz 748's Avatar
Just done mine on my 748, pull the pins out with molegrips and re-fit, I find it a lot more comfortable, wrists in a more natural position.
Old 05-Jun-2005, 10:47   #5
Thanks everybody, I knew you'd know. L3OONEY - I just want to get the bars to a more comfortable position for myself. I'm used to flatter handlebar styles. Speedymoto yoke looks well trick Nelly. How much are they in English pounds?
Old 05-Jun-2005, 14:40   #6
Rob, don't know whether this might help at all but M1KEYP has got some handlbar raisers/adjusters that look really smart, are comfortable and improve the feel of the bike.
Cannot remember what make they are (something CAT?) but possible an option?
Old 05-Jun-2005, 16:41   #7
m1keyp m1keyp is offline
They are Cyclecat DBR1
http://www.cyclecat.com/dbr1-1.htm
Excellent
Old 05-Jun-2005, 19:34   #8
£235 if i recall? Might be £250???? They are really trick pieces of kit tho
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:58.
