Old 04-Jun-2005, 11:08
ducati996dude ducati996dude is offline
Mood: Always happy on my Ducati
Another Mac user here, just get one, it will make your iLife so much easier. iMovie, iDVD etc, easy as farting.
Old 06-Jun-2005, 15:00
guest1 guest1 is offline
uncleporry:
most dvd/cd drives can be frigged open in the power down state by sticking a needle or end of a paper clip in the tiny hole in the front of the dvd/cd drawer. That should allow you to at least get the discc out without restarting.
Old 06-Jun-2005, 15:10
Sounds like Roxio doesn't support the type of DVD drive you have?
It might be worth checking for an update/patch of the roxio software and/or your cd drivers.
Old 07-Jun-2005, 01:31
uncle porry's Avatar
uncle porry uncle porry is offline
thanks i`ll give it a go
Old 07-Jun-2005, 06:54
Bionicle's Avatar
Bionicle Bionicle is offline
Roxio software sucks in my opinion always has and always will, it is known to cause the largest number of system problems.
As you have already ripped the the files to HD you should give AVS a go http://www.avsmedia.com/VideoConverter/index.aspx
Old 07-Jun-2005, 06:59
Mad Dog Bianchi's Avatar
Bikes: ST4S
does your DVD drive support the disk you are using (DVD-R, DVD+R, etc.) Do you have enough memory left for the file to use when writing. An AVI file sucks a lot of memory space for use when writing to disk.
Old 07-Jun-2005, 09:02
thanks bionicle, will try it.
mad dog, yes, dvd drive is + & - compat, if by memory you mean hard drive space , then yes, i have 11 gigs spare. roxio has a drive compatability section and my drive is supported and it lists it as working properly etc.. i think maybe roxio is corrupted, will re-install and try again.
thanks all for the help.
  #18
Old 07-Jun-2005, 09:47
Bikes: ST4S
great. Good luck. Roxio has never given me much problem and the one time I contacted them their response was fast and on the money. May want to try that as well. Tell us what you find.
  #19
Old 07-Jun-2005, 10:22
The Roxio Easy Media DVD creator that I have crashed more than I do, so it's not the best software in the world.
It also doesn't like my DVDRW drive either, but it will burn disks from ISO images, so I have to create a DVD like that then burn it!
I agree it's not the best (technically) software but it sure is easy to create a menu'd dvd using it.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:49.
