General Motorcycles only
Old 09-Jun-2005, 21:06
Lee1980's Avatar
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Mood: Xdiavel..awesome!!
Dry cluthes with open covers
I have a dp plate and clutch on my s4r, im trying not to ride it in the rain but sometimes gets rained on for hours in when left in work.
The springs have gone rusty which i knew would happen, soon to be remidied with s/steel springs.
My question is does the clutch need to be cleaned/greased more as its out in the rain a bit? as on the side stand it tips to the left can water run in anywhere?
thanks in advance
Here it is before it rained
[Edited on 9-6-2005 by Lee1980]
Old 09-Jun-2005, 21:12
keefer's Avatar
keefer keefer is offline
unless its a slipper clutch then there is not any greasing that need to be done.
shouldn't damage anything by getting wet, it will just make it rusty like you said
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
Greased!
Unless you're talking about the ramps on a slipper clutch, grease should be nowhere near it.
As for cleaning, you'll find that the plates themselves will be cleaner in an open cover than a standard one as the dust created by the friction material goes elsewhere...like all over your right boot
Water just falls out of the bottom of the casing- it's all sealed up behind the clutch so nothing to worry about there.
Old 09-Jun-2005, 21:23
Lee1980's Avatar
Bikes: Xdaivel
I meant like greasing the spring posts as they seem to squaek a bit now?
Not the plates or anything
Old 09-Jun-2005, 22:14
Rushjob's Avatar
Mood: :-)
No.......
Old 09-Jun-2005, 22:41
Lee1980's Avatar
Bikes: Xdaivel
hehe ok thanks
Guess i can clean with brake cleaner?
Old 12-Jun-2005, 22:17
yorkshire pud yorkshire pud is offline
Mood: poon tang
zinc plate full pass. your springs
Old 12-Jun-2005, 22:27
HW HW is offline
or buy a stainless set with screws for £25 from http://www.spareshack.com/
Old 17-Jun-2005, 07:22
Ducman851 Ducman851 is offline
Mood: Just Ducky
And powdercoat your Pplate as well, maybe even cut out the clutch cover to let out even more of the wonderful cacophony of sound that is a dry clutch. Ill use my 851 as an example
[Edited on 6-17-2005 by Ducman851]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:26.
