Old 04-Jul-2005, 18:57   #11
I must admit that thought crossed my mind! I'll find out tomorrow. Thanks Antonye.
Old 04-Jul-2005, 21:19   #12
Chances are if they're 3 for a tenner then they're probably very old and not likely to be XP compatible at all.
There should be no difference between Home and Pro, certainly none that would stop it running games.
Might be worth Googling for the game names and XP as this might yield some results on getting them working.
There are ways in XP to run a program as if it was 98 -
http://www.microsoft.com/windowsxp/u...ebruary18.mspx
Interestingly, this article says that XP is compatible with both 2000 and ME - ME is no more than 98 with a load of patches!
Old 04-Jul-2005, 21:19   #13
keith888 keith888 is offline
keith888's Avatar
Mood: On the up
You could try running the games using the Win98 compatability mode (right click the relevant installed EXE file then select the compatability tab). I had the same problem myself with some of the cheap kids games and this allowed most of them to run. I too do not think there will be any difference between XP home and Prof.
Keith
Old 04-Jul-2005, 22:20   #14
yeti yeti is offline
yeti's Avatar
I agree with Ant, this has f**k all to do with XP pro v home, but is more to do with ancient games that will probably only run under Dos 5 or similar ancient OS!
Tell the skinflint to but his son a cheap s/h 'puter and run 98, should work.
Old 05-Jul-2005, 01:16   #15
Nah, Keith888 has the answer. XP (home and pro) has a compatibility mode that allows programs to run in a shell with a command set representing the OS it was designed to run in originally.
Off the top of my head ... After installing the game right clink on the icon it places on the desktop and choose properties. There is a Compatibility tab, click on it and you can choose to run the program in compatibility mode and choose which OS to emulate. I've attached a picture showing the drop-down box with the options.
This should do the trick.
Old 05-Jul-2005, 14:58   #16
keith888's Avatar
Mood: On the up
I did find that on one particular game it was the installer on the CD that was crashing ie I couldn't even get the game installed in the first place. Got it eventually to work by 'exploring' the files on the CD then finding the relevant EXE files (as well as the autostart) then set each one to WIN98 compatible. I think on one I had to bypass the autoinstaller and run the install.exe manually. Bit of a faff but worth it for the look on the childs face!
Keith
Old 05-Jul-2005, 15:08   #17
Well done for reading the link I posted way up there ^^^
Old 05-Jul-2005, 15:10   #18
What link?
You go back to looking after your staff and leave the real techie stuff to those who know
Old 05-Jul-2005, 15:20   #19
Old 05-Jul-2005, 23:04   #20
guest1 guest1 is offline
In respect of the posting error warning, I managed to grab the text:
"Warning: Cannot add header information - headers already sent by (output started at /var/www/html/dsc/xmb/functions.php:801) in /var/www/html/dsc/xmb/post.php on line 692
Warning: Cannot add header information - headers already sent by (output started at /var/www/html/dsc/xmb/functions.php:801) in /var/www/html/dsc/xmb/post.php on line 693
Any help WT?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:14.
