Old 09-Sep-2005, 11:46
Mello-Yellow's Avatar
Mello-Yellow Mello-Yellow is offline
Bikes: 848 EVO & Multi 1000ds
Mood: When's the sun coming out
oil leak
Traced oil leak back up to the clutch slave cylinder. The oil is coming from were the push rod for the clutch runs through the engine and then fits into the slave cylinder. Is there a seal behind it that could be faulty or is it something a bit more serious. Had to change the rod a few weeks ago as the old one had snapped, Wondering if that has something to do with it as it could have been running out of true and worn a hole in the casing.
Old 09-Sep-2005, 12:12
There are two liitle o rings on the pushrod itself which can fail. Are you sure its oil and not clutch fluid or chain lube?
Old 09-Sep-2005, 12:33
i'm postive it's oil and not clutch fluid. Have fitted a new rod in last two weeks and washed down all around that area on tuesday night with pro wash,left slave cylinder off over night and a trace was there again last night, coming from around the rod inside the engine.
Old 09-Sep-2005, 12:49
Did you change the o rings?
Old 09-Sep-2005, 12:52
new rod came with o-rings already fitted.
Old 09-Sep-2005, 12:53
Hmmm, odd one. Maybe one of them got nipped as the rod was pushed in.
Old 09-Sep-2005, 12:55
m1keyp m1keyp is offline
Just because the rod is new does not mean that the o rings are undamaged
Old 09-Sep-2005, 13:18
True,will take it out and re-check them, They did look ok when i had a look at them. Have got a new spare one so might fit that just to see if it still does it.
Old 09-Sep-2005, 15:13
Shove a bit of grease on them before you do it. might make them slide in a bit better.
Old 10-Sep-2005, 10:49
new rod
New rod fitted last night, greased before fitting so slid in nice and easy.
Will have to wait and see now
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:40.
