Old 18-Sep-2005, 16:15
DC's Avatar
DC DC is offline
Mood: Double 9, Single 6.
coating on engine cases.
While im on the subject of engine rebuilds,..............
Does any one know of a good firm or DIY product that would enable me to paint/coat the engine cases on my 996 lump?
I am looking at the clutch casing and alternater/water pump covers. Along with the cam covers and desmo inspection covers. I am thinking along the lines of a gloss/satin black.
The engine heads, barrells and crank cases I want to keep silver. I would imagine that they will clean up very well with a bit of elbow grease etc.
Ta,
DC
Old 18-Sep-2005, 16:18
Rushjob's Avatar
Rushjob Rushjob is offline
Mood: :-)
Nelly has just done this to his new engine...looks good & a really good finish.
I know the place he had it done at is on the same industrial estate as his place is on.. give him a bell.
Andy
Old 18-Sep-2005, 16:47
There's no real rocket science involved in this one
I had all the parts shot blasted, using quite a coarse shot, then sprayed them with PJ1 satin black engine case paint.
The coarse shot gives the alloy a rough finish, and IMO, really sets the cases off. The only techy bit here is that it's increased the surface area and with the black paint helps radiate more heat off the motor
When the parts are blasted, i left any seals and inspection glasses in place to mask the machined surfaces. Also fit old screws into any exposed treads.
Make sure the water pump is extremely well masked around the pipe outlets else you'll be replacing the internal seal like I had to
I've also painted the cam belt covers black, which also sets the motor off.
Use all fresh stainless screws in the cases and you end up with a really nice looking lump
Old 18-Sep-2005, 16:54
close up on the cluch cover
Old 18-Sep-2005, 17:16
DC's Avatar
DC DC is offline
Nice one Nelly.
I was thinking along the lines of shot blasting etc. As for the PJ1 paint. I have used that before. I used the enamel I think, on a set of GSXr rims years ago. Its good stuff.
Right, I will bear that in mind. PJ1 engine paint.
I like the look that you have ended up with on the cases. Very nice. And Very nice looking lump in the frame too.
Exellent choice of clutch pressure plate by the way.
[Edited on 18-9-2005 by DC]
Old 18-Sep-2005, 18:17
Nelly's motor looks the dogs and i've seen a few other he's used the same process on which look just as good.
[Edited on 18-9-2005 by rockhopper]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:50.
