Old 27-Aug-2003, 22:44   #1
lane748 lane748 is offline
lane748's Avatar
Mood: mmmm....yellow!
Poppin\' \'n\' abackfirin\'
Can anyone tell me if I can simply replace the chip in the ECu to overcome this sometimes annoying habit this engine of mine has? It will run fine, then hiccup for no reason- like it misses a beat. a few weeks ago, it spluttered & died on me as i was entering a petrol Station (petrol light not on). Wouldnt start immediately, then let out an almighty bang. Ran perfect afterwards. It seems to run a little weak when cold too- like its gonna cut out at low revs approachin islands etc. I warm the engine up before going out, but it wont run properly until its turned it's wheels for a few miles.
The chip thats in was a Chris Clarke supplied jobbie, when they fitted their own 50mm cansto it. I suspect it could benefit from a remapped chip. trouble is, I don't want to take it in just yet to be set up, so I was wondering if its just a case of replacing the chip
Thnaks In advance for any tips/help
Old 27-Aug-2003, 22:54   #2
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
Is that the cause of the fault?
Did it start happening after the chip was swapped?
It may be something else.
But you should be able to put the original chip back in just to see if the problem goes away, or is at least different, as its likely to run weaker.
Other than that - get a chip from JHP - around £25 i reckon.
Tim
Old 28-Aug-2003, 09:19   #3
Hmm,I'm with Rattler on this one.
It could be all manner of things.My 996/998 did'nt like poor grade petrol.Also with all the hot weather we had it could be a little fuel evaporation in the system.The bikes dont like a lot of pootling around either.
It could be that the bike needs re-setting up or a service.
Old 28-Aug-2003, 10:31   #4
Mood: aving a laff
Cornerspeed
As Keefy and Tim say it could be a number of things.
If you are near to Nottingham I am sure the diagnostic computer at Cornerspeed will point it out.
Give him a call on 01623 758877.
Worth a try?
Old 28-Aug-2003, 11:05   #5
Sticky Sticky is offline
My 996 does similar (doesnt cut out though) Pops and bangs, but usually after longish spells of tootling in traffic. It has race cans on but standard chip still. I'm not worrying too much about it and will have it rechipped if necessary next service.
If it's ok for capirex and bayliss, it's good enough for me!!!
Old 28-Aug-2003, 12:27   #6
Simply replacing the chip is not enough. The new chip will have different fuelling characteristics to the old one and although these will "alter" the fuelling, the mixture could go either way depending upon the other parameters involved. Throttle balance, air bypass settings, mixture trim etc.
The only way to do it properly is to start from scratch with the TPS setting, work through it and finish off with the CO meter.
If the cans were fitted and the eprom simply "replaced" it will be all over the place. If this was the case, fitting the original one will probably improve things.
JHP's eproms are noticeably better "balanced", between the two cylinders, before setting up which if nothing else identifies the changes that an eprom causes when swapped.
Old 28-Aug-2003, 15:15   #7
One problem with replacing Eprom chips when you change exhaust systems is that if the throttle position sensor adjustment, butterfly synchronization, and air bleeds are not adjusted correctly BEFORE changing chips, minor fueling annoyances can become accentuated. These chips are programmed by the manufacturer on test bikes that are carefully set-up to Ducati specs. If your bike is out-of-spec and you use their chip, then you'll have incorrect fueling. In severe cases it will affect rideability.
Each exhaust system supplier programs their chips differently for different bike models, sometimes having one chip for a range of models to keep it simple. So the fuel map is different for different manufacturers and some bikes simply don't run as well on some chips.
Also, a complication arises when you make other changes beyond the new exhaust and chip. The manufacturer's test bike is otherwise stock, but your's may not be. For example, (at the risk of starting another contentious air filter thread) consider this:
Ducati places the superbike air filters in the air runners. This location avoids lowering the resonant frequency of the airbox (by not filling up a large portion of the airbox volume with a bulky foam filter) and avoids disturbing the airflow near the velocity stacks as well as improving throttle response by maintaining a large free air volume (giving better throttle response - which a dyno doesn't measure BTW.) between the filter location and the velocity stacks.
So unless you have installed a programmable FIM chip and done some development work on a dyno in an attempt to match the flow and resonance characteristics of your over-the-bellmouth filter you'll have to be satisfied using a chip that was developed using the stock filters. That's why the FIM distributors at Sigma Performance (www.sigmaperformance.com) recommended using the stock filters. They emphasize that all FIM chips are made and initially tuned with the stock filters, and they highly recommend staying with the stock units.
But, let's assume for the moment that you've got a new otherwise-stock bike that was set-up properly at the factory with the stock chip, or that you've got an older bike that's seen only routine service where the fuel injection hasn't been touched. After you install the new exhaust and chip, you'll need to adjust your idle mixture with the CO (carbon monoxide) trimmer.
On later superbikes, the trimmer is a potentiometer located next to the EPROM chip socket inside the ECU. It has a range of about 3/4 turn, so be careful, if you try to turn it more, it'll break off. When you rotate the trimmer screw clockwise, the injector's duration is shortened so the mixture is leaned. Counterclockwise gives a richer fuel mixture. The default position is it's rotation mid-point. The trimmer adds/subtracts a millisecond or so to each fuel pulse over the entire RPM range. So go easy, an eighth-turn on the screw is often all that's usually needed to cure low-speed rideability problems.
On 851's, 888's, and early 916's the adjustment screw is on the outside of the computer. The screw adjuster has a range of four turns, or plus/minus two turns. The default position is in the middle of the range. When you screw the adjuster clockwise the mixture is richened. The adjuster has no end stop, so if you over-adjust the screw the trimmer just rolls over at the maximum or minimum setting, without damaging the trimmer. Each time the trimmer rolls over a tiny click is just audible.
Alternatively, you can have your dealer adjust it using a CO analyzer. The factory manual calls out 1.5% CO for a stock bike to meet emissions regulations but goes on to say that best power is realized when full-throttle CO is in the 4-6% range. Keep a record of any changes so you can return to the initial setting if need be. Check the color of the inside of your tailpipes after a few hundred miles. They should be medium to dark grey, not black and sooty.
Old 28-Aug-2003, 15:31   #8
Thanks again Shazaam, another expert explanation!
One thing though - if the exhausts *are* black and sooty, which way does the fuel mixture need to be adjusted? Leaner or Richer?
Old 28-Aug-2003, 15:38   #9
Black exhaust pipes result from unburned hydrocarbons (oil and petrol) generally indicative of an overly-rich fuel condition or an air restriction such as a dirty air filter.
Old 28-Aug-2003, 17:33   #10
Monty's Avatar
Agree with Shazaam as usual. Only thing to be aware of is that since the Uk no longer supplies leaded petrol the exhaust pipe outlet will ALWAYS look black. Back in the old days when't I were a lad we could always get our pipes a nice even grey colour if the mixture was right-bloody environmentalist's.
John
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:49.
