Old 19-Nov-2005, 15:48
Paul748bp's Avatar
Paul748bp Paul748bp is offline
braided lines for Brakes
Hi there i just purchessed some goodridge lines for my front brakes i had to wait for the reducers for the calipers but im a little confussed to see if i got the right set up its completly different to the standard setup ie
the two lines come from the lever and go each to both cylinders rather than be split half way down the first line also the reducers seem to be to big ????????
can some one get some pics of there lines if they have them to see whats going on with mine im sure there right but id rather check before i have something bad happen
cheers
Old 19-Nov-2005, 17:28
m1keyp m1keyp is offline
don't understand the reducers bit but two lines are better
Old 19-Nov-2005, 18:15
Paul748bp's Avatar
the lines to the calipers
Old 19-Nov-2005, 23:40
Jon's Avatar
Jon Jon is offline
Mood: Tad more confident
Paul you need a double banjo bolt to attach the lines to the master cyclinder. I'm still not sure by what you mean by "reducers" There should be just there circular rings at each end to enable the banjo bolt to go through?
Old 20-Nov-2005, 16:22
Paul748bp's Avatar
im confussed with why have more copper washers than i need in the picture i think i have it how it should go 1 being the caliper and 2 the master cylinder
Old 20-Nov-2005, 16:32
Mood: Come on spring!!!
lines
Looks like youve got it about right but it makes it kind of confusing havin to screw the banjos into the lines, they normally are swaged onto the lines them selves
Old 20-Nov-2005, 16:43
Paul748bp's Avatar
i may take it to my local and see what they will say as it is my brakes kinda need them to work really
Old 20-Nov-2005, 23:05
They are universal goodridge lines. No problems though.
Screw the adaptors into the calipers using one copper washer.
You'll need 3 washers at the master cylinder.
Run the lines to the calipers and nip up the lines to the adaptors.
You've just been sent extra washers. Put 'em on the shelf and save for later
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:15.
