I have the same problem on my trackday fairing, also with a 50mm system, but only because the belly pan is only attached to the side fairings and not held in place with it's own brackets.
So you can either do as suggested - make up some brackets to hold it out further, get the dremel out to make it fit better or just leave it as is ... which is what I've done!
