Old 27-Jan-2006, 19:41
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Open Clutch Cover
Hello
What are the benefits of an open clutch cover on a standard clutch?
Apart from the bling factor surely as long as you clean out regulary all should be fine for road and a few track days.
or am I missing something
regards
TopiToo
Old 27-Jan-2006, 19:43
GsxrAge's Avatar
GsxrAge GsxrAge is offline
The dust will escape mate and cluch will run cooler
And they look and sound better
Old 27-Jan-2006, 20:12
I'd quite like an open clutch cover, but IMHO they only look any good with a billet pressure plate, stainless steel springs and anodised spring caps to show off underneath it, so you're getting into quite a bit of wedge.
Whenever I've had that sort of money, there's always been something that I've needed a bit more, like new tyres or something.
My ST has it's standard clutch cover, but I'm thinking about doing the same trick on it as my 888, which came with a closed carbon fibre clutch cover that has a couple of washers between each mounting point and the clutch housing, thus creating a gap to let the dust out
Old 27-Jan-2006, 20:54
Bikes: 748ish . .
Hello
Thanks for the info, not to worried what my clutch looks like as long as it does the job, like the idea of cooling it down though.
as I have a spare clutch cover I may start drilling a few holes and see what happens.
regards
TopiToo
Old 27-Jan-2006, 22:13
Bungi Bungi is offline
great idea jools, open clutch covers have always been a worry for me on trackdays in case of a trip in the gravel, should still keep the gravel out
Old 27-Jan-2006, 23:01
PDL's Avatar
PDL PDL is offline
Bikes: 803 rs race bike
When things run cooler they also perform better, hot plates expand ever so slightly. Run an open cover and you will notice a slight smoother increase in performance.
Wet clutches lose the bike Bhp as there is drag in the oil, I suspect hot expanded plates may create the same drag.
Moto GP bikes have no cover at all.
Old 28-Jan-2006, 09:53
doogalman's Avatar
If doing track days swop it over for the original. More likely to have an off. A relativly minor spill can cost heaps if the bike goes dode on the clutct. No one worried about bling on your bike at trackdays.
Old 28-Jan-2006, 10:57
m1keyp m1keyp is offline
Or get one of these
http://secure.speedymoto.com/Merchan...ory_Co de=CPP
The pressure plate should protect the posts
And then get the open cover
http://secure.speedymoto.com/Merchan...gory_Co de=CC
Nelly at Cornerspeed stocks them
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:40.
