Old 19-Mar-2006, 16:45
Linda 749R Linda 749R is offline
Mood: catch my if you can
HELP!! Termignoni 749R
Hello,
I have a qestion about the Termignoni 749R cannister.
The wining protection under the rear das not fit.
Did some off you also have this problem.
Old 19-Mar-2006, 16:50
yes it will do.......but like all things big exhaust fitting, it is a bit of a struggle. Dont expect to just bolt something on sadly, you have to take time to fit it!
Old 19-Mar-2006, 17:06
Hi Andyb,
I have put the complete Termignoni exhaust
myself including the ECU and the racingairfilters.
Only the wining protection seems to be a problem.
When i put it on the standerd cannister it will fit,
but on the Termi it comes to the edge of the cannister
and the subframe off the bike.
Gr,Linda
Old 19-Mar-2006, 18:40
nathanhu's Avatar
nathanhu nathanhu is offline
Mood: head down
they all do that ....you just have to force it ....
Old 19-Mar-2006, 19:31
Yep the tube does run very close to the subframe,.....as nathan said,you may have to force it.
Old 19-Mar-2006, 22:32
swannymere's Avatar
Mood: High as a kite!
I had the same problem with my termi can.When the tube was placed in the recess in the underneath of the exhaust and lined up all the bolts it stuck out of one end about 40mm too far.In the end i cut the excess off with a dremel
Old 04-Apr-2006, 17:05
galaxy galaxy is offline
Hu...mine fit perfectly. You can see it's close to the sub frame here, but there was no struggle to get it in, and all holes lined up perfectly. No bending, cutting, cusing, fighting required.
Old 04-Apr-2006, 19:42
The Big Red One The Big Red One is offline
Mood: Sparks will fly. If it keeps on
Looks like his pipes has stockings on I had to give mine a little bend at the end because it was i little close to the subframe. Didn't want it rubbing.
[Edited on 4-4-2006 by The Big Red One]
Old 17-Apr-2006, 14:54
bike mad's Avatar
bike mad bike mad is offline
mine was perfect fit as well
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:58.
