Old 23-Aug-2006, 20:59
Jon's Avatar
Jon Jon is offline
Mood: Tad more confident
600ss queries?
Can anyone tell me what the std rear shock is on a early 600ss. I have a Boggy one fitted which looks to be off a 748? Also what is the std lenght.
thanks.
Old 23-Aug-2006, 21:08
From what I recall the standard 600SS shock is about 330mm with the later SSie shocks being 335mm long, my Hagon shock is 7mm longer than my original 600SS shock
the Ohlins DU235 shock for the 900SS is 328mm +12mm, when fitted to a 900SSie its +5mm and -7mm as the standard injection shock is 335mm between mounting centres.
As I have just fitted a Ohlins to the 750SSie I will be able to try it at anything up to 340mm but so far have it set for 335mm while i try to sort the rest of the bike.
Old 23-Aug-2006, 21:12
I think they were all Sach-Boge.
Old 23-Aug-2006, 21:13
Jon's Avatar
Jon Jon is offline
Thx Skid I knew you wouldn't let me down, but what is the std shock or does it have no name?
Old 23-Aug-2006, 21:14
At the risk of repeating my self.
Old 23-Aug-2006, 21:18
Jon's Avatar
Jon Jon is offline
Sorry Keefy, must have been posting just has you had already. Thx.
Old 23-Aug-2006, 21:20
domski's Avatar
So it doesn't have a name then?
Old 23-Aug-2006, 21:23
[quote=domski]So it doesn't have a name then?
If they were a little worse you could call them ****
but Sachs will do
Some of the ie ones are also Sachs while some come with a Showa unit
Old 23-Aug-2006, 21:36
paynep's Avatar
Mood: Wet wet wet
Mine is called Dom, because it is gas-filled
Old 23-Aug-2006, 21:59
domski's Avatar
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:00.
