Old 07-Sep-2006, 21:13
Mood: Avatar what Avatar
Question Side Stand collapse
I parked my bike in the car park at work in the morning all ok but when I returned a few hours later the lean angle was far greater almost falling over. I had to stop for fuel on the way to Alton cafe quite scary puting on the side stand at that angle. put a pice of wood under the stand while I was at the cafe to stop it falling over, know safe at home on the paddock stand ?
The stand dose not seem to be bent, may be it's worn where it locks out?
will have to take it apart and see.
anyone else had this problem???
Old 07-Sep-2006, 21:37
Lily Lily is offline
Mood: stiff and tired
it is usually the plate that the stand fixes to that gives way. I have just put a new one on mine as it was getting a fairly significant lean angle.
About 50-60 quid if i remember correctly, but worth it if it saves the bike
Old 07-Sep-2006, 21:42
timk timk is offline
mine did that,turned out to one of the bolts holding it on had snapped,couple of quid to fix.
Old 07-Sep-2006, 21:44
Yep check the bolts for tightness...and even check to see that they haven't fallen out, one of mine did.
___________^
Old 07-Sep-2006, 21:47
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
all your bolts are for ever falling out
and it's always the same excuse "thats the one pete did up"
Old 07-Sep-2006, 21:56
My nuts are getting looser as I get older as well
Thanks god Pete has been nowhere near 'em
___________^
Old 07-Sep-2006, 22:37
My sons monsters lean angle is scary - but found one of the bolts is bent so will have to order another.
We have to stand it on one inch plate at the minute and it's still scary
Old 07-Sep-2006, 23:22
After checking your bolts, & if they are not at fault, take off the side stand & bracket, take your bracket along with your side stand to a local fabricator & explain the problem & show him the two offending items, you will see that where the side stand butts up to the mounting bracket, the soft aluminium of the side stand will be worn away a little, to rectify this add weld to the part the side stand buts up to & re shape till you get the desired lean angle. cost probably a tenner, darn site cheaper than a new side stand.
Chris.
Old 08-Sep-2006, 20:31
Just had a closer look and there is a bolt missing I don't know at this stage if its just fallen out or its snaped off will have a good look tomorow.
Thanks for all your comments
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:35.
