Old 28-Sep-2006, 22:33   #1
Douglas Douglas is offline
Panniers on a 748/916? Advice please
Hi
Anyone used Oxford panniers on their 748/916? Or any advice on using panniers on a 748 etc?
Old 28-Sep-2006, 22:54   #2
Don't!
Get a Ventura Luggage System instead - best bit of kit for touring without doubt.
Old 29-Sep-2006, 00:28   #3
Steve B Steve B is offline
Mood: counting down to mad sunday
Seconded.
Ventura makes the impossible - simple and comfortable.
1000 miles in two days last year in France with no problems.
Steve
Old 29-Sep-2006, 01:13   #4
BDG BDG is offline
BDG's Avatar
Thirded, Ventura, throwaway the throwovers!
Old 29-Sep-2006, 01:16   #5
BDG BDG is offline
BDG's Avatar
Ventura pic
Old 29-Sep-2006, 09:48   #6
Chaps, Thanks for the advice. Having looked at the Ventura system on the web, I can see its the business, the only problem is trhat they are beyond my means at present!
What are the problems with panniers? I have an old seat unit which I thought i might fit with the luggage, so I can gaffer tape it up to my hearts content. I was wondering about the exhausts, do they touch the panniers, or does the shape of the seat unit hold them away? I need an interim solution until I can afford the pukka stuff!
Old 29-Sep-2006, 11:33   #7
istanbulian istanbulian is offline
Mood: Mellow but missing Turkiye
I also could not afford Ventura but I recently did 3,000km in 2 days on my 748 SPS travelling from Istanbul to London and used a combination of a tank bag and an Oxford tail-pack on the tail section of the bike. Provided you put some sort of baffle between the tailpack and the seat unit your paint will survive. I used rubber table-matting; worked a treat. With plenty of bungess from the tail pack to the footrest hangers it was rock-solid.
The only problem with a tank bag is that it prevents you from getting close to the tank and thus limits effective top speeds to c 160-170kph unless you have a strong neck !
Old 29-Sep-2006, 12:11   #8
if you dont have rear pegs, ie not a bip, then tieing down is also difficult. I looked at doing this with a tail pack I have and, regardless of potential paint damage, there is no where to bungy them down.
Old 29-Sep-2006, 12:28   #9
rcgbob44's Avatar
Luggage on a 916.................................blasphemy!
Old 29-Sep-2006, 15:08   #10
Clippy Clippy is offline
Bikes: 1098
Clippy's Avatar
Mood: Enjoying a REAL summer!
Panniers
Oxford Humpback Throwovers work quite well on a 998 - I've done 2 trips to Italy with these and they're far more stable than a tailpack as the weights lower down and therefore causes less wobble against the single pin-type lock at the back of the seat unit.
I bungee under the numberplate holder at the back, and run a bungee between the subframe and the heatguard at the front (just behind the shock) and everything stays where it should all the way to 150+ mph.
I'll post a couple of photos if/when I can find them...
Giles
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:26.
