Old 01-Nov-2006, 21:49
sie748's Avatar
sie748 sie748 is offline
Bikes: 748 sp,748 bip , 600ss dd,speed triple.
Mood: neeeeeeed piiiiiiiiiiiiiiiiiiie
Thumbs up
mine too is a bip but says 748s on frame
Old 01-Nov-2006, 22:02
moto748 moto748 is offline
Originally Posted by antonye
It doesn't ... the sticker on the frame by your right foot is just the frame number and that has nothing to do with the spec of the bike.
Pre-2000 the 748 was available as either Biposto or SPS.
Post-2000 the 748 was available as E (same as Biposto), S or R.
E/Bip = three spoke gold wheels, gold frame
S = 5 spoke grey wheels, grey frame, TiN forks, SPS engine parts
R = 5 spoke grey wheels, grey frame, Ohlins forks & shock*, silly engine - Ti parts, overhead shower injectors, large capacity airbox, etc, etc
*except 2000 when some had Showa forks.
I don't think antonye's right about the "E". i think by the time the "E" came out, they werre all grey frames and grey (3-spoke) wheels.
At any rate, "S" models were certainly available in biposto or monoposto form. But "S" bikes have Marchesinis and adjustable steering heads, which "E" bikes don't.
Old 02-Nov-2006, 10:18
gunforhire's Avatar
gunforhire gunforhire is offline
Mood: #73 Class A newbie: I'm fitting seatbelts!
Originally Posted by DC
My 748 bip was a 99 plate with the s sticker on the frame. Came with adjustable head angle etc.
Mind you, I think that the frame is the only thing left standard now!
I think mine has as well!
I had a 2001 748E previously and the steering damper was locked in place, HOWEVER on the 1998 748BP I now have (with the S in the frame number), the damper has 2 mounting positions. I presume it's to allow for the change in steering geometry?
Old 02-Nov-2006, 10:26
Yes, all the "old" (to 2000) 748 range had adjustable steering head angles but the later E bikes didn't as part of the cost saving exercise.
Old 02-Nov-2006, 10:29
Maybe, but certainly the majority of E models will have gold frame and wheels.
All models were available in Mono or Biposto (single or dual seat) versions, but only the R bikes comes as Monos as standard. You can order a single seat for a biposto or a dual seat for an R if you really wanted. That had nothing to do with the specification of the bike itself though.
Old 02-Nov-2006, 20:55
Bungi Bungi is offline
its not just the sticker on the frame, the actual frame number probably reads 748S**** this frame number was used for std bip's also, the fact you have a reciept for the termis or whatever they are suggests the bike might have has the right kinda history. u just need to compare them to someone else bike that has propper termis to tell if they are the real thing or not the most obvious differances are the ends / exit nossles ( or whatever they are called) the weave in the carbon and the trim that are riveted at the front and rear of the carbon tube, if these all match they are probably termis.
Old 03-Nov-2006, 16:06
Paul748bp's Avatar
Paul748bp Paul748bp is offline
mine is a 1998 bip and has S on the sticker maybe Mr ducati made up too many stickers and couldnt be arsed to change em
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:45.
