Old 06-Nov-2006, 09:43   #1
Tinkler Tinkler is offline
Tinkler's Avatar
Mood: Horney
Smile Radial mastercylinder mounting
Hi there just got a Brake and clutch brembo master cylinders for my 01 748R.
But strugling a little with mounting the resovours so do any people have some photos of bracket ideas and fitting advice
thaks
Jamie
Old 06-Nov-2006, 09:52   #2
Should be lots on here, do a search.
I mounted mine on the SS via the yoke, but that was after removing the igintion
Old 06-Nov-2006, 10:20   #3
Tinkler's Avatar
Mood: Horney
Thanks thats the idea i had also but if anyone who has got a 784 - 996 style bike with master cylinders also fitted and has got photos that would be verry much apreciated
thanks
JAmie
Old 06-Nov-2006, 10:31   #4
Somebody posted up some photos of their radials not so long ago (like last week) as I remember looking at the brackets for the reserviors myself.
I think they put a slip of metal into the clamp of the radial (where the two halves bolt onto the bar) and then it was bent out into the right shape to attach a small 15ml reservoir. No point in having a huge reservoir, as long as you keep an eye on your fluid.
Have a browse through the pics section, or in this section, to see if you can find it.
Old 06-Nov-2006, 10:32   #5
Here you go, from Keefer's "I love carbon" thread...
and
Old 06-Nov-2006, 12:30   #6
mikesps mikesps is offline
I used a longer bolt on one of the bar mounts with a spacer sleeve under it. Photo possibly attached.
Old 08-Nov-2006, 18:56   #7
Tinkler's Avatar
Mood: Horney
Master cylinder
Hi there thanks for all your replys very helpfull, Got both the clutch and the brake mounted today incluing making the brackets and bleeding the system
Should have some photos soon
thanks again
Jamie
Old 28-Nov-2006, 09:32   #8
Tinkler's Avatar
Mood: Horney
manster cylinders
Okgot everything fitted and seems to be working ok, so heres how i mounted my resovours !!
Old 28-Nov-2006, 11:52   #9
khushy khushy is offline
khushy's Avatar
thats just what I did . . .
exactly the same brackets - very neat!
Khushy
Old 28-Nov-2006, 12:36   #10
did you make the brakets or are they off the shelf? If I keep sps then I have a brembo to fit over the winter and will probably be looking for a clutch one too
thanks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:42.
