Old 08-Nov-2006, 09:55
Jasper's Avatar
Jasper Jasper is offline
Fuel line QD connectors
I want to put a pair on the 888.Whats the best ones?Ducatis own?Triumph do some,i believe.M and P also.
Ideally i want straight ones.Anybody fitted aftermarket ones?
Old 08-Nov-2006, 12:22
I got mine from A&R racing off their van in the race paddock, they are fine on my 600SS which runs fairly low fuel pressure for feeding the carbs, I have yet to fit the ones to my 620 which runs higher pressures as its fuel injected. Hopefully they will be OK, Can't tell you what make they are at the moment as they're at home and i'm not, they would reasonably priced though
Old 08-Nov-2006, 12:30
We use them on our 620 without any problem, makes taking the tank off really easy.
I think they came off ebay but look very much the same as what A&R sell.
Old 08-Nov-2006, 16:11
philthy's Avatar
philthy philthy is offline
Mood: Can't make me mind up
I've thought about fitting them on the 851, but was worried about leaks from the joints. The thought of leak + heat from the engine with the obvious result put me off.
Having said that, when I used to ride Triumph bikes you had to 'tickle' the carbs to start them, which resulted in petrol dripping onto the hot motor and exhaust pipes. Aah those were t' days.
Old 08-Nov-2006, 17:11
Mr.R's Avatar
Mr.R Mr.R is offline
Hi, Iv'e fitted the A&R type 8mm id to my "92 strada, been on there a few years now with no problems so far.
Steve Robins s.w.
Old 08-Nov-2006, 19:14
http://www.arracing.co.uk/
As A&R have been mentioned a couple of times you may need the link
Old 08-Nov-2006, 19:38
Jasper's Avatar
Thanks,i'll get them tomorrow
Old 08-Nov-2006, 19:49
mjbayley's Avatar
mjbayley mjbayley is offline
Mood: Been Testing the 3 P's (Pizza, Pasta, & PERONI!)
Here are the ones we used.
LEGRIS quick disconnect
Sold by Flowtech 0845 456 1222
http://www.flowtech.co.uk/
6.4 mm ID with shut off when disconnected (in both sides)
Female side LE-9C230758P1 £5.40 each +VAT
Male Side LE-9C850758P1 £5.30 each + VAT
You may have a local stockist too, worth checking the local directory.
Mark (the pit 'biatch')
Old 08-Nov-2006, 20:54
Mr.R's Avatar
Hi, just been out to my workshop.......the original hose fitted to the 851/888 is 13 od / 8 id mm the qd fittings on my bike are nylon/white plastic in 8mm id , they are marked "CPC". I have cranked the fuel pressure up on my bike as high as 4.5 bar, changed all the clips for Jubilee type clips (in s/steel ) with no problems, i think if you were to go smaller, you may have problems with the fuel flow, on a tuned 888.
Steve Robins s.w.
Old 09-Nov-2006, 04:40
Motobee Motobee is offline
The original Ducati connectors are made by CPC (Colder Products Co.)
http://www.colder.com/asp_main/default.asp
You can buy the plastic or metal Colder connectors for about one tenth the cost of the Ducati price from a Colder distributor. People are selling these same connectors on ebay for ridiculous prices.
Brian
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:04.
