Old 06-Dec-2006, 17:43   #1
Red-Duc Red-Duc is offline
Red-Duc's Avatar
Angry Well nuts driving me nuts
Has anyone else had trouble with these?
Ive given up with the well nuts that hold the fairing on at the side, I had problems with them sliding out when riding, Ive had some new parts made and now there firmly fixed with allen bolts, washers, grommet with a metal spacer inside to stop cracking the panel.
Old 07-Dec-2006, 07:45   #2
UglyDuckling UglyDuckling is offline
Mood: Garage is getting too small....
Yep, been there a few times.....and just went and bought some newer ones.
Trick is not to over tighten them....as my old engineering lecturer once told me "there's a difference between having a good cr*p and tearing your ar$e out"
Old 07-Dec-2006, 09:29   #3
The rubber on them deteriorates quite quickly, so they will need replacing every 4-5 years, probably sooner if you use your bike in all conditions.
Speak to "mjbayley" on here if you need any as he sells them on ebay in packs for a hell of a lot cheaper than Ducati !
Old 07-Dec-2006, 10:05   #4
Yep - they are a problem at times.
I replaced my fairing fastners with large headed stainless mushroom bolts, my local stockist also does some neat stainless washers that have a 'felt' material backing to protect painwork finished off with stainless Nyloc nuts - Job done
Frank
Old 07-Dec-2006, 11:37   #5
katana katana is offline
Mood: Annoyed and confused
Or you can try rawl nuts. Same thing but made of soft plastic instead of rubber so last a lot longer and are better quality.
Oh and you can get supplies from decent hardwear shops or the nut and bolt place on the north circular near the ace cafe.
Old 07-Dec-2006, 12:03   #6
Oh yes - number plate nuts and bolts can be put to other uses too
Cheers - Frank
Old 11-Dec-2006, 14:21   #7
moto748 moto748 is offline
This is something I'm going to come up against as an SS owner now.
When I had an SS before, it was half-faired, so I didn't need to remove any plastic to change the oil.
Now I need to do an oil change, so I suppose I'll have to take the whole RHS fairing off? Is that the way to go, or is it feasible to separate the fairing and just remove the lower?
I would have thought that at least the 4 (!) fasteners underneath could be converted to Dzus à la 748/916. Has anyone done this?
The handbook says you can remove the whole lot without undoing the bottom 4 by sliding it under the bike.
But I'd imagine this would be a two-man job, cos you'd have to be very careful that you didn't scratch the paintwork on the floor manoeuvering it around.
I'm talking about an injected bike, BTW, with the "new" shape fairing.
On a brighter note, it feels much happier with a 14t front sprocket, and the suspension is much better now Louigi hasd fettled it for me.
Old 11-Dec-2006, 16:06   #8
Monty's Avatar
So which 'SS' do you have? I have a 1000ss project which is being fettled at the moment-going to have a very small half fairing on that which I got from Ducati Kamna in Germany-won't be a problem for me to change the oil-the picture shows the original nose part of the standard fairing, new one is only slightly larger.
John
Growing old-disgracefully!
Old 11-Dec-2006, 19:47   #9
John
Fully faired 900SSie in yellow.
Having just bought the bike, I can't say I feel much like going to the expense of buying new fairings, especially when the existing ones are in such good condition.
Only drawback I recall with the half-faired bike was the paint lifting off the engine casings especially the LHS (nearest the gutter).
Old 11-Dec-2006, 19:50   #10
Red-Duc> Any details available of those "parts" you had made?
Drawings, sketches, photos? Pretty please?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:07.
