Old 15-Dec-2006, 14:20   #1
multi600 multi600 is offline
multi600's Avatar
Mood: Hopefull
Machining Barrels
I am planning to set the squish and dial the valves for next season. Anyone know what would be a reasonable price to pay for the bottoms of the barrels machining. Can anyone recommend somewhere to do the work ,preferably local to the Southampton area, but I suppose I could post if there is nowhere local.
Mike
Old 15-Dec-2006, 14:38   #2
Rattler Rattler is offline
Rattler's Avatar
Mood: www.cantbearsed.co.uk
You can't modify the barrels under the rules - so machining is a big no no.
Tim
Old 15-Dec-2006, 15:04   #3
paynep's Avatar
Mood: Wet wet wet
Using a thinner or no base gasket is what Motorapido did on my 675 & 583 and will be doing on my 620.
Old 15-Dec-2006, 20:26   #4
Founder Member
Paul James's Avatar
Originally Posted by multi600
I am planning to set the squish and dial the valves for next season. Mike
Best bit of work you could spend time on IMHO. I can machine barrels in my workshop, I'm looking at doing some for a conversion kit (NOT DD related).
http://www.multirole-eng.com
Old 15-Dec-2006, 21:16   #5
multi600's Avatar
Mood: Hopefull
Tim
As they are all different sizes when they leave the factory who is to say if they have been machined. And setting the squish is not against the rules and it may involve machining a small amount off the base. Afterall it's only setting the engine up as it should have been done in the factory.
Mike
Old 15-Dec-2006, 21:20   #6
They're not that far out. Using different base gaskets is all that's needed. As Tim said, it's a no no under the rules.
Old 15-Dec-2006, 22:06   #7
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
Mike
The rools are the rools mike, 'manufacturing tollerances' aint an excuse!
Just use thinner gaskets... same effect.
Old 15-Dec-2006, 22:29   #8
Rattler's Avatar
Mike
Nice try
Old 15-Dec-2006, 22:34   #9
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
I feel a protest coming!
Old 15-Dec-2006, 22:39   #10
DSC Member AK AK is offline
AK's Avatar
do i need more tools?
or will they be suplied? or maybe not
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:14.
