Old 29-Dec-2003, 22:55   #1
chicken chicken is offline
chicken's Avatar
buzzing tank
When I turn the ignition on (but before starting the bike) I hear a loud buzzing from the tank which I think is the fuel pump.
Is this normal for a 96 900ss or should I be shopping for a new pump before this one goes kaput?
Old 29-Dec-2003, 23:22   #2
Dont think you should worry - my '93 900ss fuel pump makes a fair amount of noise too and still keeps on going. I was going to change the fuel filter on mine but after removing the filler cap and housing and having a poke about inside - I decided against it since everything looked pretty clean.
I guess as long as the noise is consistant (primed) and the bike runs fine otherwise, it sounds ok.
Regards - Frank
Old 30-Dec-2003, 22:34   #3
chicken's Avatar
thanks for the advice Frank.
One less thing to worry about. Now, about the frame welding, suspension, clutch, lights, brakes......:P
Old 30-Dec-2003, 22:52   #4
Hee Hee....
Frame welds...check em all, esp headstock
Sus...overhaul front...White Power do a nice cheap (£250) shox for the back
Clutch - JHP do a nice upgrade slave cylinder to reduce the lever effort
Lights ..... Halogen or increase power
Brakes .... Better pads (check the board, Carbone Lorraine, etc) braided lines ( run one line down to wheel, then jump a one over/under the mudguard..... Nissin Master cyclinder or 6 - pot upgrade
Its all down to time/money/enthuasiam I guess.....
Good Luck .... Happy New Year.....
Nice 2 c another 2Valver on the site
Regards - Frank
Old 30-Dec-2003, 23:06   #5
chicken's Avatar
mmm...all sounds yummy...
I know the money spent on upgrades will never add to the value (as evidenced by the guy I bought the bike from!). On the other hand, this is the bike that I have always wanted and I'm going to keep her forever!!!!
The enthusiasm is there but time and money is in short supply. Will hopefully get a bit of both in the spring....
Happy new year to you and yours. Drop me a line if you are in the docklands area - first drink is on me! (goes for everyone else on the board).
cheers, Chi
Old 31-Dec-2003, 11:42   #6
SSTU SSTU is offline
Little picture
Choose a picture from a website
Right click on it select properties then wright down the location of the picture ie.
http//:www.littlepicture.com
Go to message board and click on Control Panel / Options at the top righthand corner of the page then click edit profile
scroll down untill you come to the box marked Avatar. Type in the location of the pictue then scroll down to the bottom of the page and click edit. if it works you will see the picture in your profile.
Good luck
SSTU.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:53.
