Old 19-Feb-2004, 12:11
Harv748's Avatar
Harv748 Harv748 is offline
9** subframe interchangability!
I'm been thinking about changing my 748 Bip for something else, such as a 996sps etc..but I do need to be able to carry a pillion now and again.
With, for example, a 996sps (or any of the 9** mono range), is it possible (and simple!) to change the mono subframe over to a bip one and be able to carry a pillion? How many of the parts are interchangable...is it just the subframe (and obviouslt the seat unit) that would need swapping over?
Old 19-Feb-2004, 13:10
This website will help:
http://www.gastric.com/toys/ducatibip2mono.htm#1
Old 19-Feb-2004, 13:17
Harv748's Avatar
thanks for the repies...but not quite what I'm after.
The link shows a Bip being converted to a mono...which is what I have actually done to my current bike. However...I want to know If I can go the otherway...from mono to Bip...particularly on a bike such as a 996 SPS?
I would have to change the subframe over to a BIP type...so will a bip subframe fit? Will the ECU etc locate OK in the new frame? Is there anything that could stop me from changing over the rear to allow for a pillion??
Has anyone done it?
Old 19-Feb-2004, 20:36
Karl's Avatar
DSC Member Karl Karl is offline
Harv
Guido has done it to his 748r, I think he has a webpage on it.
Old 19-Feb-2004, 21:35
ducv2 ducv2 is offline
I've seen it done on a 996 SPS, it required a bip subframe (steel), which was then modified to take the sps ecu, which I think is a bit bigger than a normal 996 one. The subframe stayed put all the time, seat units being swopped as neccesary. Appears the job is quite easy if you have access to a mig. Hope that helps
Old 19-Feb-2004, 21:40
748 Daz did it on his 748R.
He had all the bip bits for sale recently.
Old 19-Feb-2004, 22:15
As mentioned with the 996SPS the P8 computer mount is different to the one on the Bips which use the IAW 1.6 ECU, as does a 748R making the same job on a R easier, if you go for a 998 the computer is not a consideration as the 5.9 ECU sits on the side of the battery box.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:37.
