Old 06-Mar-2009, 15:17   #1
Fastfasulli Fastfasulli is offline
Chain......errr...gang
Hi again peeps,
I've woken out of hibernation and am starting to sort my DD bike.
Anyone know what kind of chain I should look for for if I ain't got no riveter tool thingy? Is there any other? Oh, and are they cheap?...lol It's for my 600ss.
Answers on a post card please :-))
Old 06-Mar-2009, 15:21   #2
mjbayley mjbayley is offline
mjbayley's Avatar
Mood: Been Testing the 3 P's (Pizza, Pasta, & PERONI!)
Originally Posted by Fastfasulli
Hi again peeps,
Angle grinder, lump hammer, ball pein hammer !!
Thanks for showing me how to do it, Amazing Al... !!
Old 06-Mar-2009, 16:38   #3
ali ali is offline
ali's Avatar
Mood: Damp
I paid about £30 for mine last year (trackside) but it wasn't the best quality. You should be able to pick a decent branded one up for £45 with a bit of shopping around.
Angle grinder / dremel.
Old 06-Mar-2009, 18:24   #4
Tsubaki "Alpha X" X Ring Gold Chain in 520 size will be around £60 and is a brilliant chain. Had one on mine since the start of DD in 2005 and it's still perfect.
http://www.bandcexpress.co.uk/
Old 06-Mar-2009, 22:14   #5
Thanks chaps. That Tsubaki chain may just be the job Antonye - cheers
Old 09-Mar-2009, 23:11   #6
Does anyone know what the standard length of chain is for the SS? What size sprockets does that enable you to run?
Old 09-Mar-2009, 23:23   #7
Depends on the year of your engine and the output shaft (paging Skidlids, Skidlids to the courtesy telephone please!) as to what size sprockets you want to run and therefore the size of the chain.
I think mine is a 96 link chain, but I know we bought a 100 link and then cut a couple off once we'd put a sprocket on and put the wheel in the middle of the adjusters.
Old 09-Mar-2009, 23:25   #8
Some info:
http://www.bandcexpress.co.uk/cgi-bi...OAD&nav=Ducati
Frank
Old 09-Mar-2009, 23:57   #9
faith-healer faith-healer is offline
Thanks for the link Frank
Old 10-Mar-2009, 00:43   #10
As Antony says it depends on the engine, if its a genuine SS engine then it will have either the early 2.28 to 1 primary drive and use rear sprockets in the region of 38 to 41, in which case the chain length should ber 98, if its the later SS engine with 2 to 1 primary then sprocket sizes that I used were 41 to 43 which gives a chain option of 98 or 100 link
Dallas's bike hasa 1999 Monster 600 engine in it with the 1.85 primary so has to use bigger rear sprockets and a 100 or 102 link chain
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:11.
