Old 10-Jul-2009, 00:38   #1
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
Where to buy - 996 racing ally rear subframe
Can anyone recommend me a good place to buy an ally rear racing subframe for a 996?
Thanks!
Old 10-Jul-2009, 09:28   #2
boggy 8 boggy 8 is offline
try moto46
Old 10-Jul-2009, 11:02   #3
Originally Posted by boggy 8
try moto46
Thanks. Will call them.
Old 10-Jul-2009, 13:25   #4
pguenet pguenet is offline
Carefull, 996 and 748 are almost the same but not quite.
996 is based on the SPS one and was designed to take the P8 whereas the 748 was designed for the 1.6. Not that it matters that much for the ECU because a race bike has it front mounted anyhow... but the carbon seat supports are different for either bikes.
Old 10-Jul-2009, 16:44   #5
Right so, a 748SPS or 748R subframe should work, right?
Not sure we'll have the necessary time to sort a wiring harness to front mount the ECU.
Old 11-Jul-2009, 10:50   #6
powerwheelie powerwheelie is offline
Itīs not going to fit properly. I went through it with my 748S ECU and wiring harness. Bought a 996 al subframe and had to lengthen the wiring loom by about 10cm.
Old 11-Jul-2009, 15:47   #7
This any good for you???
http://cgi.ebay.co.uk/ducati-748-916... A1%7C294%3A50
Old 11-Jul-2009, 15:55   #8
Depends what ECU you run.
If you run a P8 you need to look for a 996 ally subframe - generally coming from 996 SPS bikes.
Old 11-Jul-2009, 15:56   #9
Originally Posted by chris.p
That one looks like a 748 one to me.
Old 11-Jul-2009, 17:18   #10
Yes, thatīs one for the M1.6 ECU.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:50.
