Old 15-Sep-2009, 23:29   #1
Dougie748 Dougie748 is offline
Dougie748's Avatar
Mood: Alway's smiling when on my Duke
Ducati 748 sleep mode alarm
Hi I have a problem with my Ducati 748. Bike not used for a couple of weeks and when I pressed the meta alarm key fob to disarm there is nothing. Looks like the alarm has went into sleep mode. I have tried switching on the ignition but the fuel pump does not prime but all the lights are working. Battery has a full charge.
How do I re-boot the meta alarm?
Thanks in advance
Doug
Old 15-Sep-2009, 23:58   #2
748adam 748adam is offline
748adam's Avatar
take it off
sorry could'nt resist hahaha
Old 15-Sep-2009, 23:59   #3
Dougie748's Avatar
Hi Adam I would if I new how.
Old 16-Sep-2009, 00:11   #4
Ray Ray is offline
Ray's Avatar
Try holding the alarm fob nearer to the alarm unit on the bike, this might help is the battery in the fob is a bit weak.
Ray
Old 16-Sep-2009, 00:12   #5
Googled Meta Alarms and this is what came back, should/ might be able to find what you need here.
http://www.metasystem.co.uk/index.ph...rcycle_area/55
Old 16-Sep-2009, 00:27   #6
Dougie748's Avatar
Hi Chris I have these instructions but when I turn the ignition on no alarm sounds and pressing the alarm remote does nothing.
Im sure the alarm is stuck in sleep mode though so I just need to find out how to get it out the sleep mode by means of reboot or reset.
Old 16-Sep-2009, 00:29   #7
Drop them an email quoting your system and bike along with the problem.
Old 16-Sep-2009, 00:30   #8
Setting it off (ie, jiggle the bike!) used to work for me.
Then it went wrong proper and left me stranded in town, so it got taken off.
Might be worth getting it looked at to be on the safe side!
Old 16-Sep-2009, 00:39   #9
Dougie748's Avatar
Hi Antonye tried shaking the bike too but no alarm sounding. The led does not even come on.
Yes looks like Ill need to have someone check it out.
Just thought I would post this as someone may know how to get it out of sleep mode.
Old 16-Sep-2009, 01:16   #10
748adam's Avatar
just out of interest whay model number is it (usually on a sticker on the alarm box) as i have recently had to take a meta off an R6 as the battery on the bike went flat, when the customer conected the new battery it blew the relays in the alarm box.
The alarm model in question was only supplied for about 6 months then Meta changed the design and re-called all the faulty one's.
Thought it might be worth a mention!!
Adam
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:02.
