Old 16-Aug-2011, 20:48   #1
r15suk r15suk is offline
r15suk's Avatar
Help with more comfort for a taller rider.
Hi,
I've had my 996 for about a year now and i'd like to make the riding position a bit more comfortable. I'm just over 6 ft and 50 years old!
Have any tall riders out there had a positive result from fitting helli bars, and/or adjustable rearsets?
Another area is the screen. I'd like to fit one that will help reduce the wind blast, but on my Fireblade a double bubble actually made this worse and i fitted a Zero Gravity sports touring screen in the end.
Thanks in advance.
Simon
Old 16-Aug-2011, 21:24   #2
A corse racing screen is good, about £35 off ebay, and I had the cyclecat adjustable bar risers and they made a huge difference, but I aint of 6'
Old 17-Aug-2011, 01:30   #3
Cranker V2's Avatar
Mood: Green with envy
Corse screen makes sense, not sure rearsets will improve> Back and up is the norm with rearsets. Also be aware thet bar risers may cause bar/clutch/brake/ lever interference with upper fairing,
Old 17-Aug-2011, 07:26   #4
One thing that is easy to do is to move the brake & clutch levers into a more downward angle onthe bars, you need to remove or cut off the pins that lock them into the position that they are in, then turn them around the bars a bit till they are at a more confertable angle for your wrists before tightening them back up.
I have done this on both of the 748's I have had, it makes town riding less of an ache on the wrists.
Old 20-Aug-2011, 09:44   #5
r15suk's Avatar
Thanks for the advice. I'll check out the screen and try adjusting the control levers first before looking at bar risers.
cheers
Simon
Old 01-Sep-2011, 17:22   #6
Cobbett Cobbett is offline
Bikes: 750ss, 998s
Cobbett's Avatar
Might some kind soul post a link to a corse screen? I'm considering the same option but ain't exactly sure what I'm looking for.
Old 01-Sep-2011, 23:14   #7
Check out - Laminar Lip
Old 02-Sep-2011, 00:03   #8
Fast By Ferracci Handle Bar clamps have less of an angle which may help with bar position
Rearsets with the two mounting points and the pegs on eccentric cams should give more leg room, although I have known someone to fit footrest risers for the standard pegs the wrong way so that they lowered the pegs, that gave them more leg room.
Not sure if Wulfie has any mods as he's a tall guy, makes his 748 look like a mini-moto
James (aka 007) is also tall and seems to get on well with his 996, not sure what mods he has made if any
Old 02-Sep-2011, 00:15   #9
Go for something like this:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=290599990619
Just search for "ducati screen" on ebay and there's loads of options and styles.
You want a "double-bubble" or race/corse screen. There's a couple of different styles and different options on clear, smoked, dark, etc, so take your pick!
I'm 6 foot tall and found a screen like this made a big difference on my 748, as it pushed the wind over my head instead of it hitting me in the face & shoulders. I have a slightly different shape (will try and find a picture!) but very similar to this one.
Old 02-Sep-2011, 00:18   #10
yep, that looks about right like mine. It was about £30 from memory plus a bit of p&p and is ace
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:23.
