  #61
Old 08-Aug-2011, 18:29
chris99 chris99 is offline
Mood: building the beast
Good luck Phillipe
I cheat as I use the local powder coaters
Looking good Chris, do you still need the order for the pump wiring
I do now the other site has shut down. DOH!
  #62
Old 08-Aug-2011, 18:32
smilo006's Avatar
smilo006 smilo006 is offline
Mood: I like my bike
regarding your fuel connectors. Triumph do them. Reasonably priced as I recall. Might have a couple somewhere. In my experience it is the gromit that breaks not the male connector or the female connector (typical)
  #63
Old 08-Aug-2011, 22:43
In the crash the tank ripped off and snapped them. Nightmare
  #64
Old 01-Sep-2011, 02:39
Well i got another load of bits from Ducati Leeds which i hope will just about get the bike done.
The starter relay was fooked before the crash and sitting for five years hasn't helped. The new one looks just the ticket.
Also got the new quick release fuel fixings from Tom Parker. Had a nightmare getting the "right ones" These will do the trick though.
I decided to treat myself to some frame bungs from ebay. Very happy with these
I also picked up a screen.
I even managed to get some oil and coolant in her and fired her up for a while. So far so good!
Just some odd bits to do and then an mot. Paint will be done over winter. I just want to have a run out before the weather really turns.
  #65
Old 01-Sep-2011, 06:26
Like the fuel connectors, do you have the part numbers, price etc ???
  #66
Old 01-Sep-2011, 10:06
Hope you're sitting down mate :0)
Female fittings cLCD100040V 1/4" BSPT with shut off valve - Viton seals
£14.95 each + vat
Male fittings cLCD230-06V 3/8" with shut off valve - Viton seals
£15.76 each + vat
Toal with postage to me was £79.64 which stung a bit but they'll never break.
Plastic ones are half the cost. The thread in the tank is an NPT thread but CPC have never made fittings with an NPT thread and Viton seals. It seems that the BSPT thread is the same type but the sides are a constant width. The NPT threaded hole gets smaller as you screw in. I added some ptfe tape and wound them in tight. They seal fine so in not bothered. I'd rather know the seals wont give up.
I got them here www.tom-parker.co.uk 01772 251405
  #67
Old 01-Sep-2011, 22:14
Originally Posted by chris99
Does anyone know where the thread is about fitting 999 master cylinders. Someone kindly posted the part numbers needed for the remote reservoirs that i will need. I've searched but can't find it.
Here you go - did it myself using this and it's very easy!
http://www.ducatisportingclub.com/sh...ad.php?t=42582
  #68
Old 01-Sep-2011, 22:17
Hmm... seat bracket? Seat rubber clip thing? Headlight adjuster screw and spring?
You should have asked - think I have a few of those bits kicking around!
  #69
Old 18-Sep-2011, 22:03
Ah didn't even think to ask. Just wanted to get it on the road asap.
  #70
Old 18-Sep-2011, 22:12
I've been pottering over the last few details before MOT. Mostly just making sure every bolt is tight. Got some Ti rear hub pinch bolts.
I got them because they wont rust. Each saves 20g so i'm sure i'll notice lol
Just for fun i decided to lockwire the grips. I like the race bike look.
I got a bit keen and ordered the full fairing kit in stainless steel from probolt. I've also got a couple of bits on order from QB carbon.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:59.
