Old 14-Oct-2011, 20:08   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Bike storage question please
Hello,
I need to store my bike for the winter,
My concern really is how too make sure I have covered
all the main points.
Tyres are pumped up
Fresh fuel in the tank
Optimate on
Loads of carpets and blankets
But . . .
Should I remove the plugs and squirt a drop of oil
into the heads and keep the plugs out of the bike.
If so how much oil are we talking?
Any other pointers would be most helpful.
K.regards
TopiToo
Old 14-Oct-2011, 21:10   #2
You either want a completely empty or a completely full tank. This stops air in the tank reacting with the water in the fuel and rusting your tank.
I'd be tempted to apply a liberal coating of WD40 around the electrics as well to both drive out moisture and to stop things becoming too dry.
If you're only storing for a few months, it's probably not worth bothering with much else engine wise. I cracked open my 748 engine after it has sat in the garage since last May and there was plenty of oil around the insides!
Old 14-Oct-2011, 21:35   #3
Bikes: 748ish . .
Hi Antonye,
Thank you for the pointers,
problem I have is it maybe more than a few months, last year I did spray the bike with some water repellent, which worked well,
my concern would be seized pistons or scouring the barrels due to lack of oil when it gets warmer on startup.
I am not keen on just turning the engine over every few months during the colder periods of winter,
but have done so in gear etc without starting the bike.
Old 14-Oct-2011, 22:31   #4
Loads of info at a whole load of websites, most of it sensible:
http://www.google.co.uk/search?q=mot...e+storage+prep
Most recommend about 5cc of oil into the barrels, then turn the engine over a couple of times to distribute.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:24.
