Old 29-Jan-2012, 13:08   #1
Air box options
What's the real benefit of removing the air box? I read in the regs that you can remove it, but what do you gain? More induction air I guess?
Old 29-Jan-2012, 13:39   #2
Debateable I guess
Airbox is big enough to supply the 900/1000 with enough air to make 85-95bhp with standard restrictive filter and makes for a good Plenum Chamber, upgrading to a race filter can only improve things. Most restrictive part of the standard box is the lid which is easily disposed of.
i have seen plenty of bikes running a standard airbox, race filter and no lid making the Class limit on BHP.
Some airboxes get cut to seperate the Battery and Electrics so they don't have to be removed everytime you want to work on the carbs or the throttle bodies
Old 29-Jan-2012, 13:43   #3
Jolley Jolley is offline
Bikes: 959
Jolley's Avatar
My B bike made better midrange (around 5bhp more) with the airbox and standard lid.
Old 29-Jan-2012, 13:48   #4
only reason I'm junking mine is so I can accommodate the tank swap, otherwise I'd leave as is with high flow filter and no lid
Old 29-Jan-2012, 14:38   #5
Thank you great info. I was going to just take the lid off but it also made good power on the dyno with the lid on and a k and n. Just for info had it done at the dyno centre. It's run by ex bsb racer Stuart Nicholson and great value for money. Well I thought so!! 01609 760466
Old 29-Jan-2012, 20:01   #6
so was it like Jolley says; better midrange with lid on?
Old 30-Jan-2012, 11:31   #7
Yes better with it on.
Old 30-Jan-2012, 11:55   #8
Have a read...
http://www.ducatisportingclub.com/sh...ad.php?t=41331
Old 30-Jan-2012, 23:42   #9
That's one brilliant post.
Old 30-Jan-2012, 23:59   #10
But not relevant to our little bikes. Superbike a have a chamber with pressurised air, where our tiddlers don't. Certainly not from research I've been reading
Only way to know is back to back dyno which SP has done, hope to do the same and see the outcome. Shame if it's worse tho, have to keep the weight and look of the monster tank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:01.
