Old 28-Mar-2012, 23:11   #11
Spjallen Spjallen is offline
Pivot is fine as long as I don't use circlips on the ends. The oem steel swinging arm held the pivot bolt in place with those. Seems the alloy arm is slightly wider. The rear axle looks too long. I'll have a play tomorrow. Thanks for all the comments. Shim of a job so far!!
Old 28-Mar-2012, 23:42   #12
Simon which Alloy arm did you get, there are three different ones that I know of to fit the 20mm spidle on the back of the engine. I'll rule out it being the latest one, making it either the early one with the adjusters inside the swing arm and the adjusting bolts sticking out of the end plates as they did on the steel swinger or the more common alloy arm found on most 900SS's with the adjuster blocks on the outside pressed up against the adjusting bolts
Old 29-Mar-2012, 11:21   #13
Kev, it's a 750 ss alloy one with more normal style chain adjusters - bolt and lock nut type, not the ones that fall out of the ends! The pivot bolt on my steel ss one had circlips on both ends, but to make this one fit I've taken off the circlips and it's now flush with the swingingarm. Seems ok but not 100% sure. The lower suspension bolt also was different but with a different - slightly longer - bolt it seems ok too. Just left with finding the tq settings for the pivot bolt clamps and making the rear axle fit. Which I don't think it does, maybe too long or needs washers.
Old 29-Mar-2012, 11:50   #14
Pretty sure that's what I did with mine when I converted it!
http://www.horrible.demon.co.uk/bikes/2006_new.jpg
Old 29-Mar-2012, 14:34   #15
Thanks. Now I know who built this bike, I must have read the story quite a few times before I took the plunge of DD. Great looking bike and brilliant write up.
Swingarm is on now. Found out the pivot bolt clamps tq it's 37 nm. Measured the rear axle it's about 6 mm too long. Are a few washers an acceptable answer to this problem?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:02.
