DSC Website - Help and Notices
Information on using the site & requests for help or suggestions, as well as notices about site changes, updates and downtime.
Old 18-Apr-2012, 14:29   #21
DSC Member MJS MJS is offline
Bikes: None at the moment
MJS's Avatar
Mood: Feeling old...
The only problem I get is, the new posts total is now showing huge numbers.... over a 100 at times... when there's really only half a dozen...
Everything else works fine for me
Old 18-Apr-2012, 14:45   #22
That is correct - it is counting the News Feeds section in the new posts total, but it excludes them from the New Posts page to stop it polluting that page!
Old 18-Apr-2012, 15:31   #23
Cranker V2's Avatar
Mood: Green with envy
Please send it Antonye,
I will get one of the IT types in work to look at your configuration. Still p****s me off that as members we can't get it fixed by a IT professional. I know I moaning, but I pays me money and expects delivery of services that are of sufficient standard to enable all to have the same FUNCTIONING facilities within the forum space.
Mike, off to play with a delta v issue.
Old 18-Apr-2012, 17:40   #24
Sure no problem, just drop me an email address you'd like it zipped to.
The issue is that it's an older version of the vBB system with no support from the vendor any more, and the browsers have moved on since then, so it appears that while some work fine (as witnessed above) others don't (as also witnessed above).
Personally I'd like to rip out this whole vBB system and replace it with something newer (as there's a lot of "features" which really **** me off too!) and it was one of the objectives set out by the new MT, but unfortunately there doesn't seem to have been any progress made on that so far.
Old 18-Apr-2012, 18:02   #25
not alone - when I use my ipad or ipod, it wont work. I have noticed it comes up as a number in the address bar, but if I select the bar and look at previous, it comes up 'get-daily' then it works...no idea what it means!!
Old 20-Apr-2012, 22:31   #26
Right, after a bit more digging with Google I *think* I might have just fixed it by changing some of the settings for cookies.
I did a quick check on the iPad and it seems ok, but if others can check and let me know if it works I would be grateful!
Old 20-Apr-2012, 23:03   #27
Ha! After a bit more fiddling I've also fixed the formatting of the Quick Links drop-down menu, for those browsers that support it ... and all I need to do now is update that browser list if I can find it!!
Old 24-Apr-2012, 11:59   #28
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
Ant for the 1st time in what seems weeks it is now working on my home machine with Windows 7 and IE9.
Well done that man!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:18.
