Old 13-May-2012, 19:52   #1
jangol jangol is offline
Bikes: 1098s, 749
749 Brake Judder/Loud Noise
Help Please..
On way home earlier, on pulling my front brake, I'm getting a serious vibration & noise...
Any ideas what it could
I ride a 03 749bp 13k miles.. (I've owned since Jan 2012) so not added to many miles yet...
Thanks in advance
Old 14-May-2012, 17:20   #2
Originally Posted by jangol
Help Please..
Thanks in advance
Warped disc?
Glazed pads?
Steering head bearings?
Old 14-May-2012, 17:33   #3
Bikes: 1098s, 749
Thanks for the info...
Whats Glazed pads?
Old 14-May-2012, 20:57   #4
It's more likely to be brake dust build up in your brake calipers stopping the pistons from moving freely.
If you haven't already, get the calipers off and give them a damn good clean with an old toothbrush and some brake cleaner to get rid of all the crud.
For glazing, check your pads - if there's a rainbow sheen on them then they may be "glazed", but you can put a sheet of fine sand paper on a piece of glass (to ensure it's flat) and lightly take the sheen off. They'll be good as new.
Old 27-May-2012, 20:56   #5
Bikes: 1098s, 749
As always, work gets in the way of everything....
Took Front brakes off yesterday & as per your suggestion the 2 pistons RH side & 1 Piston on LH side (as you sit on the bike) had seized.... Took alot of cleaning to bring them back to life.
went for a short ride today & all appears to be fine...
Finger crossed it does the job.
Thanks for the heads up
Regards
JA
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:21.
