Old 13-Jun-2012, 18:32   #1
hawkati hawkati is offline
Bikes: ducati 996, hawkati, kawacati
hawkati's Avatar
Mood: generally vile and mischevious
996 stering head angle?
Sooo - bought 996 through here. All good. Marvellous in fact!
Quick query though - the steering head angle is set to race, ie steeper. The givaway for this was the fact that the steering lock now cannot work. Nevermind, i've lived with it like that for about 1,000 miles, but in fitting a 190/55 rear i might have tipped it over the edge. At Anglesey recently i couldn't dial out a feeling that the front would tuck -never had this on my old bike. Similarly when riding on dodgy B-roads. just a bit too twitchy for its own good. Just rummaged in a haynes manual who are quite emphatic that this should not be switched from the road setting.
You lot have acres road & track experience -what say you? Many thanks, jamess
Old 13-Jun-2012, 18:44   #2
Personally, I never got on with the steep setting, road or track. I run 190/50 rear (6" rear) and use the rear ride height to sharpen the front up. Front forks also at stock height
Old 13-Jun-2012, 19:38   #3
dunlop0_1's Avatar
From what I am told the race position head angle is best used with the longer swing arm and the rear hub set to it's highest point.
Old 13-Jun-2012, 19:58   #4
http://www.ducatisportingclub.com/sh...ad.php?t=46067
Old 14-Jun-2012, 14:40   #5
hawkati's Avatar
Originally Posted by Shazaam!
Indeed! I had a rummage of that, minutes after slinging up the original question, and will definitely revert to road setting. It's worth a fettling session methinks, and might remove the uncertainty from B-road shire zooping! As for track, well, booked for the PB thingit on July 6th at Cadwell( yes, i know, there's a crucial one on the 9th too - maybe, if funds permit!) so i'll see how it behaves on track too. Cheers y'all!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:52.
