Old 10-Dec-2012, 19:05   #1
yeendy yeendy is offline
Bikes: vfr 1200 dd b class 350 honda
yeendy's Avatar
Mood: generally quiet pleasant
dumb DD race prep questions from non ducati man
well chaps i have completed all the paperwork , got the bike , all i need know is a bit of help from you old sages and i should be out to play next year,
the bike i have purchased is a monster which has a bikini fairing and belly pan , what do i need to fit a full fairing as i prefer that look ,
the bike is an ex DD race bike which raced last year at cadwell. do i need to do any winter maint on the bike besides oil and filter, ie drain tank and carbs , belts, etc , the bike is kept in a warm dry place so the winter will not harm my new toy, sorry for the dumb questions , cheers in advance
Old 10-Dec-2012, 19:15   #2
Well you will need a full fairing to start with, then just fashion brackets to secure it. I only use a Bikini fairing, easy fix when it goes down the road or off it completely.
As its been raced you will want to treat it to some decent oil and filter. Belts are not overly dear on the 583 so put a pair on. Just have a good check around as if something can fall off it certainly will. So cable tie multi-plugs together after making sure terminals are clean and silicone greased.
Just obvious house keeping really. Good luck with it.
Old 10-Dec-2012, 19:31   #3
bally71's Avatar
Mood: Inquisitive cat
got a 1098 fairing on mine .. was a pretty easy to fit .. had a new fairing stay made by chaz ..little bit of cutting around the bars and a couple of brackets and le voila .. mucho sexy time
Old 10-Dec-2012, 19:57   #4
dunlop0_1's Avatar
Make sure things that should be tight are tight and things that are supposed to come undone do so.
All the stuff Ghost said but remember not fully synthetic oil.
Book a TD in Feb.
Old 10-Dec-2012, 22:21   #5
banger san's Avatar
Why not fully synthetic?
Old 10-Dec-2012, 22:26   #6
Fully synthetic ok on a 583, but not a 620 as the clutch will slip till it gets hot.
Old 10-Dec-2012, 23:01   #7
banger san's Avatar
There's been a lot said about about clutches slipping when synthetics are used, that is typically caused by using oils with friction modifiers in them, a good quality synthetic designed for use in a motorcycle engine is unlikely to have friction modifier added so the clutch should not slip.
Andy
Old 11-Dec-2012, 05:24   #8
dunlop0_1's Avatar
Also the cost.
Old 11-Dec-2012, 06:36   #9
banger san's Avatar
Also the cost.
That's one reason I do understand
Old 11-Dec-2012, 10:13   #10
When DD first started, many years ago, we were all given sponsorship packs from Shell which included their fully synthetic oil.
I think just about everyone had problems with clutch slip using that, but once we switched to the semi-synth it was resolved.
The fully synth didn't go to waste - it went in my 748 instead
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:50.
