Old 19-Dec-2012, 18:58   #1
Jonzi Jonzi is offline
Bikes: Monster 796, Class B 600ss
Quick Action throttle
Is it worth it?
If so does any one know where I can get one for a 600ss from? Google fails me
Old 19-Dec-2012, 19:30   #2
I think the usual choice is between Domino and Venhill
Old 19-Dec-2012, 20:03   #3
Or a std SS ie one its what I used gives about 60 deg of rotation.
Old 19-Dec-2012, 22:15   #4
Or a 748/916 etc
Old 20-Dec-2012, 19:14   #5
gerrard#22 gerrard#22 is offline
Bikes: ducati 620/yamaha r1/aprilia rs125/montesa 349 cota
Mood: leg dangler ;)
i use a venhill one its meant for a motorcross bike but its spot on, you can choose from two different settings
Old 20-Dec-2012, 20:42   #6
Try this link. Loads there
http://www.redracingparts.com/englis...n/roadrace.php
Old 20-Dec-2012, 22:11   #7
That's great! thanks for the link
Last question!
How do I know which one of those I can use? I know nothing of these things.
I assume I would need to get a throttle and cables?
Old 20-Dec-2012, 23:10   #8
I used 356203 on the advice of Birthday boy Skids. That uses the original cable and ditched the other one - sp kust one cable now. This advice is for a 620 ss. The grey beards and dd minds will advise which is best for the 600cc bikes.
Old 21-Dec-2012, 06:42   #9
dunlop0_1's Avatar
IMO unless you have tonnes of BHP on tap a quick action is not really of any advantage on a DD bike. As Phil & Paul said standard is the way to go. Not only the cost but also the availablity as the throttle housing is one of the first things that can disintergrate in a spill.
Old 21-Dec-2012, 10:40   #10
Ditch the closing cable as it's really not needed - those springs will have your fingers off anyway!
You can then go to a single cable throttle, and use a 916 sized one (62º iirc) or get the one from Red Racing Parts (356203) which is actually the same as the 916 one but is branded Domino instead of being OEM
The standard SS one is 90º so it's a twist and a half to get full throttle! Once I'd swapped over I always found the throttle much easier to use.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:02.
