Old 28-Apr-2013, 14:14   #1
Jonzi Jonzi is offline
Bikes: Monster 796, Class B 600ss
Keyless and what can be removed
For those that have gone keyless. Help!!
I have bypassed the ignition key and want to know what else can be removed.
Does the general relay, fuse box and the other big black box thing can go
(Saying "big black box thing" probably means I should leave this alone)
Any pro tips greatly appreciated
Old 28-Apr-2013, 14:38   #2
You need to sit down with the wiring diagram Dan. Are all the lighting and indicator wires still in the loom?
Old 28-Apr-2013, 14:50   #3
Easier to bin the wireing loom, think it is only 4-5 wires that you need to run a class B, drop BimJob a message and ask how many & where they go.
Old 28-Apr-2013, 14:55   #4
Everything is still there just cut off
I've got a Haynes and going through the wiring diagram on that
I think I was hasty in posting. So far it seems ok.
Old 28-Apr-2013, 14:59   #5
How does the actual ignition unit come off?
There are some conical shaped nuts that hold it on which look like thy have a thread on the inside.
Do I need something special to remove that?
Old 28-Apr-2013, 18:02   #6
Most of the wiring has now gone.
Can the neutral switch be removed from the crankcase or should that just be cut and left?
Same for the oil pressure switch, take it out or cut it off and tape up?
The ignition barrel is still on as I can't work out how the thing comes off.
There are two conical smooth bolts holding it on, they have a thread on the inside. Any ideas how I undo them?
Old 28-Apr-2013, 18:13   #7
Neutral switch can be cut, but try and leave the oil pressure light on, two reasons, first is the obvious one, incase you have an oil pressure problem, can save your engine, also by having it still on is to make sure that you know if some one has turned your ignition on or you have left it on.
Old 28-Apr-2013, 22:41   #8
I use an Easy out for removing the Ignition Switch bolts
http://compare.ebay.co.uk/like/26103...ff14=64&ff19=0
Old 28-Apr-2013, 23:15   #9
Easiest way it to get a long bolt that is the same thread size as inside the cone (M6), and put a nut onto it. Wind the bolt (with nut) into the cone as far as you can then lock the bolt in place with the nut. Undo the bolt and it will bring the cone out with it!
Click image for larger version Name:	cone_bolt.JPG Views:	482 Size:	34.7 KB ID:	13506
Old 06-May-2013, 18:54   #10
I think I am dumb.
I tried this but it didn't work. I did manage to bend a couple of bolts though.
I did exactly as you said except when I undid the bolt the bolt + the nut simply come out.
What am I doing wrong?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:15.
